Flux core pipe
发表于 2021-8-31 22:36:21 | 显示全部楼层 |阅读模式
Anyone welding flux core
Reply:Which kind, gas shielded, or self shielded?Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Self shield
Reply:I’ve done a little on structural pipe. 99% of it had chill rings.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:New to flux core welding .. just wondering  is there much work for it out there ??
Reply:In structural construction, there is always work for people who can run flux core!Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Just welding a few pipes on the horizontal  at the moment
Reply:Here’s a few pictures of projects I’ve been involved in that were all welded with flux core. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Wow massive  jobs . That is what I would like to do some time get on jobs like that ..
Reply:Those were all done with self shielded flux core?
Reply:The 10-feet diameter pipe was welded with dual shield. 100% x-ray. All the other work was done with self shielded flux core. To weld the 10-feet pipe we needed a tent. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:We use DualShield fill and cap on our smaller pipe.
Reply:Pipe spool fabrication shops and offshore yards on the Gulf Coast run gas shielded flux cored all the time.  Self shielded fluxcore is still pretty much limited to structural work in the states.Overseas you can find oil and gas pipelines welded with self shielded flux core; mostly on tie-ins and in terrain where the mechanized pipe bugs can't be used.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:I weld with gas shielded in a tank shop… we use it to weld out pipe flanges, etc.- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Cam have u any pics of ur welds just to see if I'm on the right track
Reply:Originally Posted by ireweldCam have u any pics of ur welds just to see if I'm on the right track
Reply:you have to be careful with you health, because a lot of smoke coming out.
Reply:Timmy that looks a good weld
Reply:What were ur aettings
Reply:Yes there is a lot of smoke from it if I was to do a lot of it I wud by the proper gear
GMT+8, 2025-12-30 20:06 , Processed in 0.101548 second(s), 18 queries .
