Why do I think this is a real bad idea
发表于 2021-8-31 22:36:21 | 显示全部楼层 |阅读模式
Not mine, from another forumWelding a long pintle hitchhttp://www.benzworld.org/forums/unim...extension.htmlHis procedureBeveled all 4 pieces then welded it with mig an Stargon gas. I would weld an let cool-- etc etc over a 5 day span
Reply:very bad idea. better lawyer up
Reply:I could weld a reinforcement bridge from end to end using 1/2 " by maybe 3-4" but it will never be loaded maxed and only pulled on hi-way. Never off camber stuff. When I ground/beveled the ends, the Sparks that came off both pieces showed higher carbon content. The mig welds should be fine. I could have used E7018 rod but mig is much easier an cleaner. I will post some pics this weekend. Am at school today.
Reply:I'm sure this will end well You may want to add IN BOLD that you didn't work on it.Everyone knows what happens in these threads Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Remember, he said he was only using it on the HIGHWAY!!!!!ChrisAuction Addict
Reply:At least he won't be going fast with a Unimog
Reply:You think it is a bad idea because you have common sense....Not too many do anymore unfortunately....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:5 days to complete the welds?? Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Wouldn’t want to be him when a CHP officer sees that! Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by AKweldshop5 days to complete the welds??
Reply:He could have used 7018 but mig is easier and cleaner. He states this because he obviously can't weld worth a darn using 7018.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I would have never done that in a million years! I would go this route first. I built this hitch years ago for a friend. So he can pull his horse trailer with his camper in the bed. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by Rock knockerAt least he won't be going fast with a Unimog
Reply:He did the complete opposite of pre- and post- heating too.
Reply:Originally Posted by CEPWouldn’t want to be him when a CHP officer sees that!
Reply:Somebodies feelings must have gotten hurt Attached Images
Reply:Whelp, that didn't take long.... Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Originally Posted by weldermike
Reply:Well, the paint looks nice....
Reply:I think we all know that would worked perfectly if only it had been downhill 6013.SA-250 TMDSquarewave 200Thunderbolt AC/DC1951 G.E. welder
Reply:I wonder where the "welder" found a piece of rebar thick enough to scab in...
Reply:I can hear it now "I can't believe that thing broke off so easily, I welded it for 5 days!".GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by KelvinI wonder where the "welder" found a piece of rebar thick enough to scab in...
Reply:That pos is probably going to bend under the tongue weight alone... what a clown.Welding/Fab Pics: www.UtahWeld.com
Reply:Nah, if it's re-bar it'll snap off nice and clean! A few weldersA lot of hammersA whole lot of C-clampsHe did say that he used a round torsion bar or maybe an axle.
Reply:Oh, yeah. I do remember that now.Heat treated parts to heat treated parts with 6011??NO PROBLEM! Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:wonder what this guy does for a living. Dentist?
Reply:Originally Posted by 7A749Oh, yeah. I do remember that now.Heat treated parts to heat treated parts with 6011??NO PROBLEM!
Reply:Yeah, yeah... I knew there was an explanation for it.... Expert Garage Hack....https://www.facebook.com/steven.webber.948
GMT+8, 2025-12-30 21:51 , Processed in 0.257607 second(s), 18 queries .
