What do i need to get for Oxy Propane.
发表于 2021-8-31 22:36:17 | 显示全部楼层 |阅读模式
I have a Victor Torch that was used for Oxy/AccI have also have an oxy regulator.I have a High Flow Propane Reg that does 0-50 PSi. Will that be sufficient for Cutting?Is there a specific tip i need to get for the torch?
Reply:A set of Victor propane tips and propane hose set is all else you'll need to use your torch with propane.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:The propane hose set that DesertRider33 is refering to is twin fuel hose grade "T". Grade "R" is for acetylene only."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Yeah figured i would need hose dont have any atm.You think a 50 Psi reg will be fine?
Reply:The pressure of 50 psi is fine for propane, but you want make sure the flow capabilities of the regulator will be enough.  Most manufacturer have flow charts.  Determine the cubic foot per hour needs of your tip and check the flow chart to make sure the regulator will deliver enough gas at the pressure needed for that tip.OAdoctorwww.regulatortorchrepair.com
Reply:Originally Posted by OAdoctorThe pressure of 50 psi is fine for propane, but you want make sure the flow capabilities of the regulator will be enough.  Most manufacturer have flow charts.  Determine the cubic foot per hour needs of your tip and check the flow chart to make sure the regulator will deliver enough gas at the pressure needed for that tip.
GMT+8, 2025-12-30 21:57 , Processed in 0.141102 second(s), 18 queries .
