Inline flow checker.....
发表于 2021-8-31 22:36:08 | 显示全部楼层 |阅读模式
Kinda got a huge surprise yesterday when I tried my new gadget (Inline flow gauge)  With the regulator set for 10 CFH  it barely registered......I had to turn the reg up to 20 before it registered 10Hmmmmmm are these things accurate?Anyone have problems with the Speedway 320 torches flow wise?Last edited by B_C; 01-24-2014 at 12:45 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Yours is not listed in CFH - it's graduated in lpm - mulitply by 2.12 to get cfhLast edited by MinnesotaDave; 01-24-2014 at 12:54 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:No way really?  Damn Im glad you told me that because the LWS sure didnt.....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:DUH.......It says LPM  right on it.....It sucks being old .....lol  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by B_CDUH.......It says LPM  right on it.....It sucks being old .....lol
Reply:How long is the initial gas surge on your setup?Mine is a good 2-3 seconds of blasting past where the meter can read.I have to let that surge out before I start welding an aluminum inside corner or it can screw up my start with a loud erratic arc.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I had that issue on my Tig 355 Lincoln especially with the WP-18 torch........I just accepted it and did what you do and waited till the RUSH was over to weld.....One day I had time to mess around and shortened up the supply hose to the machine from the regulator and most of the problem went away. There was a large volume of space in that extra hose so it built up pressure I guess......taking away that extra volume lessened the pressure build up....Try shortening the supply hose to just what is needed to connect the regulator to the machine and see what happens?   Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:That's exactly what is wrong with mine - I have a ten foot supply hose feeding it.I'll have to figure where to move my machine so I can get the tank in a better spot.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:There's a company that makes a couple things to reduce the surge.  I think it's primarily a smaller diameter hose and a reducing orifice at the end that connects to the welder.  http://netwelding.com/http://netwelding.com/How_GSS_Works.htm"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:BC, I have one of these,http://dantack.com/browse/productDet...oduct=ESA19043and have checked my Smith flowmeters and they match dead nutz.......flow gauges not so much
Reply:Originally Posted by vwguy3BC, I have one of these,http://dantack.com/browse/productDet...oduct=ESA19043and have checked my Smith flowmeters and they match dead nutz.......flow gauges not so much
Reply:Originally Posted by MinnesotaDaveYours is not listed in CFH - it's graduated in lpm - mulitply by 2.12 to get cfh
Reply:Originally Posted by dave powelsonThe conversion you're stating is wholly different thanwhat Arc-Zone depicts for this unit:"Measures in Liters Per Minute. To Convert to CFH Divide - LPM/.472=CFH"IOW---divide LPM by .472  to obtain CF/hr. flow
Reply:Originally Posted by MinnesotaDaveNow you're just messing with people, dividing by 0.472 is the same thing as multipying by 2.12 I prefer the multiplication 'cause I can do that in my head
Reply:Originally Posted by Oscarah the beauty of intimately knowing mathematics
Reply:My bottles are close to my machine so a shorter hose wasnt a problem.....I think using a hose with a smaller IDwould be a good idea if length is an issue......Same deal just different....lol  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Why do you have one flowmeter feeding the other?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleWhy do you have one flowmeter feeding the other?
GMT+8, 2025-12-30 21:21 , Processed in 0.157560 second(s), 18 queries .
