looking for advice on my weld
发表于 2021-8-31 22:36:04 | 显示全部楼层 |阅读模式
We had a ladder bracket break on one of our fire trucks.  The department replaced it so I got to take home the broken one and play with it.  It was a cast aluminum covered in chrome.  I put a V in the crack, sanded back the chrome.  Pre heated it and then wire brushed the crap out of it.  I would run about an inch or so bead then wire brush some more. Machine settings were set at the max on the Dynasty.  AC balance  at 65 and frequency was at 120.  Seemed like I was getting a good puddle and penetration all the way through.  Miller Dynasty 200DXMillermatic 211 AutosetESAB PCM 875 plasma
Reply:oh and this will not be going back in service, its just in the scrap bucket now.Miller Dynasty 200DXMillermatic 211 AutosetESAB PCM 875 plasma
Reply:It looks good, you just need to work on your angle and consistency.Sent from under a Miller welding helmet
GMT+8, 2025-12-30 22:52 , Processed in 0.117505 second(s), 18 queries .
