anybody have this happen ?
发表于 2021-8-31 22:35:59 | 显示全部楼层 |阅读模式
ust wondering if this ever happened to anyone else. i was welding with my lincoln electric weld pak 100 and out of nowhere the wire feed stopped. i thought the spool was empty and turned it off and checked. the spool was still half full so i turned it back on and it's worked fine since,.\am i hallucinating, or does this sometimes happen with wire feed machines or should i dust off the receipt. i bought the machine in july and have been very happy with it.thankskev
Reply:kevcheck the connections at the torch and in the unit it selfregardschipmasterRanger 250LN 252 ESAB suitcase feedersSP135LINCOLN Square Wave TIG 255Kondia vert millProtoTrak CNC vertical mill13" South Bend Lathe17" South Bend Lathecaterpillar d-4, 15, 22 and a 20
Reply:You hit the duty cycle happened to me to yeserday!
Reply:Yup, duty cycle's only 20%, but dont turn it off, the fan will cool it off faster.(If it has a fan)
Reply:If your input 110VAC drops to 90VAC you duty cycle will drop to 12%,  Plus a 25 extension cord will drop the duty cycle to about 10%The Lincolns are know for high power consumption
Reply:Originally Posted by MetalSculptorIf your input 110VAC drops to 90VAC you duty cycle will drop to 12%,  Plus a 25 extension cord will drop the duty cycle to about 10%The Lincolns are know for high power consumption
GMT+8, 2025-12-30 21:21 , Processed in 0.110759 second(s), 18 queries .
