Lincoln power mig 200 problem
发表于 2021-8-31 22:35:58 | 显示全部楼层 |阅读模式
the machine runs, the wire feeds but won't burn the wire. this happen once before but started working again. can anybody help?Lincoln Power Mig 200Ready Welder spool gunLincoln Tomb Stone AC DCMPM 150 AMP DC portable Arc welder and GeneratorRiland 40 AMP Plazma Cutter
Reply:what happen may come in handy for someone else and I was lucky to find out the problem. Something told me to check the Voltage coming in my house and I was getting 253 volts. My mig was shutting down. I called DEMCO my Electric CO. and they came out checked to see if I was wright ( I was ) hurried to the substation and turn it downLincoln Power Mig 200Ready Welder spool gunLincoln Tomb Stone AC DCMPM 150 AMP DC portable Arc welder and GeneratorRiland 40 AMP Plazma Cutter
Reply:i had a simler thing happen at work the compersure keep bolwing fuses i checkedthe in comeing volts not 440 v like it should be 575V i called con ed told themthay told me thay did not have a problem but an hour later it was back down to440vChuckASME Pressure Vessel welder
GMT+8, 2025-12-30 21:21 , Processed in 0.114674 second(s), 18 queries .
