Air cooled torch to Liquid
发表于 2021-8-31 22:35:56 | 显示全部楼层 |阅读模式
I have a PT 185 and the torch gets hot while welding aluminum, I'm toying with the idea of comverting to a liquid cooled torch but the lincoln setup is a little salty...  Has anyone done this with aftermarket components  ie, Build your own cooler/ torch-cable combos??  If so I'd really like to get some ideas. The lincoln setup is like almost 400 without the cooler, 900 with.
Reply:Just posted this the other day...http://www.weldingweb.com/vbb/showthread.php?t=4417Smithboy...if it ain't broke, you ain't tryin'.
Reply:You're right, the price of these things is a killer for most of us.  If you want to build your own power cable, water hose, and gas hose, this company manufactures all the standard brass fittings you will need:http://www.westernenterprises.com/
GMT+8, 2025-12-30 21:21 , Processed in 0.107178 second(s), 18 queries .
