V160t
发表于 2021-8-31 22:35:56 | 显示全部楼层 |阅读模式
im getting a V160 T tig /stick welder and was woundering if anyone here has ever used one?ChuckASME Pressure Vessel welder
Reply:Yes, they have been used by people before.  Next question!Owner of Welding Wiki,The free wiki based resource for weldor's around the world.http://www.weldingwiki.comWe have cookies!
Reply:well it came in last nigth now i have to get a stinger tig torch and foot amptroland a tank of argon  i wish it came ready to weld but i can see why it dont im thinking on getting a weldcraft wp-17 for my tig torch because i have a wp-26 at  my dads house with lots of collits and the parts interchange betweenthem and i use a wp-17 at work for a stinger im going to try to get one from the store to day and some stick so i can playChuckASME Pressure Vessel welder
Reply:good luck chuck,  let us know how it works for yaIF it Catches...Let it Burn
Reply:thanks but it will have to be after the new year none of the store by me have a stinger that will fit and none of the welding shop's are open on the weekend so i will have to be content just to look at it happy new year all ChuckASME Pressure Vessel welder
Reply:bummer...see ive always got a stinger layin around.   no tig torch...but a stinger would suffice for finding out atleast solme of machines capabilties.    it does pay to have a bobus layin around some times IF it Catches...Let it Burn
Reply:ok to day i got some 3/32 6011 rod and a stinger from work ran some test beedsnow i dont get to stick weld that much any more and i like to run hot  so i turned her up to 117 amp and found to two things right off the bat one is that 117 amp for 3/32 rod is way to hot and the breakers in my shop wont hold so after resetting the welder to 91 amp and resetting the breakerstill to hot and yes the breaker went out to ok take three set the machine to 67 amp and reset the breaker YEA! we got weld  run real good later this week ill get new breakers and my owne stinger and more time to play and well see if i can still stick weldChuckASME Pressure Vessel welder
Reply:lol   good job chuck,    have fun with it....im sure you willIF it Catches...Let it Burn
Reply:I use the same machine, just on the miller side. You have to run that baby on 20 amp circuits, not 15's.  I ran in to the same problem, I tried to get away with it but no matter what I had the machine set at it will trip a 15 amp breaker.  Good Luck                                      Dave
Reply:i got 20 but there not slow blowChuckASME Pressure Vessel welder
Reply:i ordered the torch and stinger tuesday hope thay come in tomarowi need to weld im starting to twitch ChuckASME Pressure Vessel welder
Reply:lol send picsIF it Catches...Let it Burn
Reply:Of him twitching?
Reply:yes I love to see welders twitching...especially when they are standing there in a puddle of water and they got sparks flyin out their hat IF it Catches...Let it Burn
Reply:here it is Attached ImagesChuckASME Pressure Vessel welder
Reply:here are some welds with it the electrode is 3/16 6011 69-73 amppositon was f2 now eather the 6011 suck or i need to get back in to stick welding   Attached ImagesChuckASME Pressure Vessel welder
Reply:lol chuck,  3/16 6011?  what thickness plate?       they look like youre running stringers....maybe a lil more heat and pause a littke longer, just a pinch.  but they look pretty good.  practice practice IF it Catches...Let it Burn
Reply:That seems like a pretty low setting for 3/16. Maybe a typo? And isn't6011 an a/c rod? I'd turn it up a bit.
Reply:6011 is both ac and dc.  I dont know of any rod thats only ac.  They will all run better on dcIF it Catches...Let it Burn
Reply:im hoping its a typo and if it is,  or just a misunderstanding of what he intended to say was the plate is 3/16 but i want know what dia rod it is.  also,  6011 is tough to make look good.....takes lots of practice with that rod just to make it pretty its lookin good as far as im concerrnedIF it Catches...Let it Burn
Reply:3/8 plate and 3/16 is a type-o i ment 3/32 i cant even get the size right but if i can run vert up with .045 wire then i should beable to relearn to stickChuckASME Pressure Vessel welder
Reply:I know ya can....I betcha 10 mins with my bobus and Id have you running 6011 uphill, turned around backwards with a mirror while doing a handstand!IF it Catches...Let it Burn
Reply:got me some heilum and did some dc puls aluminum tiging to day and it works greatChuckASME Pressure Vessel welder
GMT+8, 2025-12-30 22:53 , Processed in 0.107731 second(s), 18 queries .
