any and all info about this forker i bought
发表于 2021-8-31 22:35:51 | 显示全部楼层 |阅读模式
I bought this fork yesterday, i needed a bigger one than my 2000lb. cap. three wheeler. so I found this one for $700....and it is BIGGER  any one know what model it might be? It is a Yale where might i find the ID tag? looks repainted and probably painted over the tag. (I can't find one) It is a 6 cyl. eng, and gas. i was told it is a Continental but again no ID tag. everything works great except the engine, I can't get high rpm (backfires) starts and idles fine. would love to get info so i know what engine i'm working on .... Attached Images
Reply:I gave away an old Towmotor that resembled yours. Now I'm kicking myself."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:after driving my little 3 wheeler Hyster, i climb into this and it's like going from a piper cub to a 747............. I have to get some info on the motor, timing/firing order
Reply:Originally Posted by 1awert1. . . It is a 6 cyl. eng, and gas. i was told it is a Continental but again no ID tag. everything works great except the engine, I can't get high rpm (backfires) starts and idles fine. would love to get info so i know what engine i'm working on ....
Reply:Looks EXACTLY like one I used to have to use at a former job. If the starter is on the left, battery on the right and leaks fluid everywhere. Ours was also repainted... former USN equipment. Where are you located?  try looking on the back of the starter battery rack?any numbers stamped on the top side of the frame below the hood panels?I can remember in the 7th grade my mom said "people will offer you drugs" by the 10th grade I was like, "where the hell are these people?"
Reply:the roll cage screams tow motor.   but with the "Modifications" to the operator safety cage its hard to guess.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:At one point in time Towmotor stamped the serial number into the front frame crossmember plate up near the top.I can remember in the 7th grade my mom said "people will offer you drugs" by the 10th grade I was like, "where the hell are these people?"
Reply:as your sitting in the seat, the starter is on your right and battery is also on right side. Manifold and down draft carb also on right side. I heard chrysler  had some 6 cyl. in forks, i wonder if it is a chrys. and not a continental....This don't leak anything, tires are real good, looks like it was taken care of. (somewhat anyhow) What do you guy's mean by TOW Motor??? was that a type of yale?
Reply:TOWMOTOR was a forklift company. Bought out by CAT in 1965. They were produced with both names on them for some time.http://www.af.nl/prive/heftrucks/towmotor/towmotor/I can remember in the 7th grade my mom said "people will offer you drugs" by the 10th grade I was like, "where the hell are these people?"
Reply:Originally Posted by 1awert1. . .I heard chrysler  had some 6 cyl. in forks, i wonder if it is a chrys. and not a continental....
Reply:this is for sure a YALE fork, as the word YALE is cut into the  back. I got the number 1ND30 off the engine, does that sound like a chrysler???  I know it does not sound like a continental, as i have owned several....Guy i bought it from said it was a continental though, he also said it weighed 8000 lb. Now i don't think so, i think it has a lifting cap. of 8000 and weighs abound11000.
Reply:Originally Posted by 1awert1. . .I got the number 1ND30 off the engine, does that sound like a chrysler???. . .
Reply:Denrep, old Chrysler 225ci slant 6? Great motor..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Well this is an L-head that predates the slant-6, but also a good 'ol mill.Good Luck
Reply:the slant 6 was a great motor, but it's no slant 6, i will do some googleing and see what i can find on the 1960ish chy. mill....
Reply:O.K. now i'm getting someplace..... It is a Chrysler engine, seller said "It's a continental"  It is a 230 industrial "L" 6 flathead. now it will be ez to find some info on timing and other things.....Great job guy's....
Reply:In some regions/locations any forklift may be called a "towmotor".
Reply:Replace the points in the distributor.  Your high speed backfire sounds like it's electrical.  I would give it a total tuneup, points, condensor, plugs, plug wires, ignition timing shopuld do it.  Those ld engines are simple and easy to repair.  Nice find, good luck with it.FredMiller 330 A/BPDynaflux R1000 coolerLinde HDA-300 HP-18 torchHobart BetaMig 251Hobart Handler 135 Campbell Hausfeld 80P&H 181 Arc Century 295 Arc Hypertherm Powermax 900 Plasma cutterSeveral Oxy/Acc torch and tanks
Reply:Well I put new plugs in, took the distributor  apart cleaned up the points, cleaned and inspected the manual advance mech. changed air filter, and gas filter, fired it up and ran perfect..... all i have left to do is fix (replace) the master brake cyl. ......Now i can start cleaning up the trail blazer 250 that i bought today for $780, and hopefully sell for a profit...
GMT+8, 2025-12-30 23:26 , Processed in 0.071491 second(s), 18 queries .
