Picked up Lincoln Idealarc SP-200 at an auction this weekend....
发表于 2021-8-31 22:35:50 | 显示全部楼层 |阅读模式
Went to an auction Sat and ended up getting this Lincoln Idealarc sp-200.  It was kinda covered in dust and stuff as it had been stored in the basement at a car dealership.  Got it home and plugged it in the 220 outlet and it worked!  I got it cheap enough that I took a chance on it.  I opened the door to look at the spool, which it had a big spool of what looked to be copper it had all the orig paperwork and owners manual.  Also an extra liner.  Cleaned it up and it looks ok compared to when it rolled off my trailer from the auction.  Any secrets or tips to this thing to make it better? Attached Images
Reply:Tip #1: Crate it and ship it to: MY HOUSE! Nice find. I would say blow it out and run it for awhile.
Reply:I got it for 200 bucks so I guess thats real good.  I'm waiting to get 220 service to the big shop to use it.  I have a Millermatic 140 right now, which has been great, but I think this sp-200 will be good also.  I want to see the difference between the miller 140 and the sp-200 first hand.
Reply:First off, you suck.  I can't find deals like that to save my life.  Second, awesome deal.  We look forward to seeing pictures of the results.
Reply:Originally Posted by FegenbushFirst off, you suck.  I can't find deals like that to save my life.  Second, awesome deal.  We look forward to seeing pictures of the results.
Reply:Copper colored wire would be steel hard wire. They copper coat it I think to keep it from rusting. Should be a tag somewhere on the spool listing what it is. -DanOwnerDW Metalworks LLCMiller Trailblazer 302Miller 8RC FeederMiller Passport PlusMiller Dynasty 200 DX W/Coolmate 1Hobart Handler 135Hypertherm PowerMAX 30Smith O/A Torch SetPlus much much more
Reply:Originally Posted by mark12  Any secrets or tips to this thing to make it better?
Reply:I have a SP-200 also These were/some of the best migs Lincoln has ever produced. I got mine a year ago, it is a GREAT welder.Well first, take that stupid bracket off of the lift!If you want two tanks, make a duel top holder.Then get it wired in and WELD, WELD, WELD, oh have fun too.P.S. use the stitch from time to time, it works very nice.
Reply:Well I got power to use the welder now.....playing with it this morning.  I do have a couple of questions....I started on some scrap.....what is causing all the drippings?  I bumped the power down 2 clicks and also dialed back the wire speed, but still got the drippings.  Is this because I don't have any gas on it?  Also noticed it almost looks like a torch when welding.  I can flames around the tip when I weld too.  I am used to seeing a whitish film when I weld with the millermatic 140, with this sp200 I'm seeing a brown/copper film around the welds.    This wire says spooled alloy steel, dia .030, AWS A5.18, ER70S-6 if any of that helps. Attached Images
Reply:I'm betting you have flux core in your millermatic 140 (flux core does not require a shielding gas, and leaves a whithish / grey powdery film that wipes off), and the wire in your new mig is solid wire, which absolutely does require gas. You will not have any kind of reasonably good results wthout gas. If you don't want to use gas, buy a spool of flux core for it.JasonXMT 350 MPA Dynasty 280DXSuitcase 8RC / OptimaSpoolmatic 30AThermco Ar / C02 mixerAssorted O/A gear
Reply:http://www.praxair.com/praxair.nsf/0/c56dbfa8e80d0dbd85256ab300140b28/$FILE/P-8126.pdfEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I had a feeling it was because I didn't have gas on it....I will pull the bottle off of my millermatic and hook up to the sp200 and see what happens then.  I will report back the results.  Thanks for the quick replys!
Reply:OK so I think I'm getting the hang of the adjustments on this thing....snapped a few pics the first two are with the sp200, one is after I brushed it with the wire brush, the last is from my millermatic 140 running .030 flux core wire.  I've never ran solid wire with gas through it, but running solid wire with gas on the sp200 is night and day difference. Attached Images
Reply:Remember to switch the polarity if you switch from gas to flux core.  Your tips will thank you for it.
Reply:Originally Posted by FegenbushRemember to switch the polarity if you switch from gas to flux core.  Your tips will thank you for it.
GMT+8, 2025-12-30 23:27 , Processed in 0.275093 second(s), 18 queries .
