I give up...where is the I.D. tag on TB
发表于 2021-8-31 22:35:49 | 显示全部楼层 |阅读模式
I bought a Trailblazer the other day, would like to know the year of the thing.....It's a 250G with the 20hp onan...where is that dang serial number???
Reply:i hope it wasn't removed?!?Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:On my Bobcat, there's a sticker right on the front of the machine.  Shows model and serial number and current output and duty cycle info.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Mine is the same as DR. About a 2"X3" tag in between the lead bolts, on the front of the machine.You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:If you can't find a serial number anywhere else on the machine, look for the engine serial number on the engine itself, then call Miller with that serial number and they should be able to trace it back to the machine serial number.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Don't know if Miller still does but they used to put a SN sticker inside on the backside of the control panel.  They typically fell off as time went on and all I've ever seen on older units is where the sticker glue remained on the panel but no sticker.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:No wonder i couldn't find it  It was right in front of me on the front panel..... Made in june of 1995, got it running today, runs good, now i have to check out the sparking ability.....tomorrow if the weather allows me...
GMT+8, 2025-12-30 21:57 , Processed in 0.094644 second(s), 18 queries .
