TIG differences
发表于 2021-8-31 22:35:44 | 显示全部楼层 |阅读模式
I am trying to figure out the differences between scratch start and lift start.  The only TIG machine I have used is HF.  I plan on buying a TIG machine pretty soon and I'm sure I won't be able to afford an HF machine.  Any help in understanding would be greatly appreciated.ThanksLincoln 175Monkey Wards 230v.  Stick
Reply:Lift arc will help keep from contaminating the tungsten. It can also control an argon solenoid so you don't have to use a torch with a valve.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Squirmy,Thanks for the video. It was very informative.
GMT+8, 2025-12-30 21:57 , Processed in 0.097364 second(s), 18 queries .
