Which flux wire to use?
发表于 2021-8-31 22:35:43 | 显示全部楼层 |阅读模式
New to mig, and have a Hobart Handler 140.Not sure what wire (.030) was on it, when I got it, but when I replaced it, I bought some Fusion Flow .035 flux wire from a welding supplier. It worked better. I was welding 3/16 steel.I bought a 2# spool to try it. They were out of the 10# spools. What .035 flux wire do you folks like?I'll be buying a 10# spool, and don't want to buy wrong.Thanks for any info.
Reply:This is a good general purpose self shielded wire. http://www.hobartbrothers.com/produc...d%26reg%3B+21BDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:NR-211 is not quite as nice but available in .030 which might be a better size for the Handler 140. You can get it at Home Despot and Blowes.JohnA few weldersA lot of hammersA whole lot of C-clamps
GMT+8, 2025-12-30 21:57 , Processed in 0.107479 second(s), 18 queries .
