Hobart Porta-wire needs contactor
发表于 2021-8-31 22:35:43 | 显示全部楼层 |阅读模式
I have a Hobart Porta-wire suitcase feeder that doesn't have a contactor. I'm  wondering if I can just add a 400 amp contactor with 12v coil and power it if the gas solenoid circuit? Does anyone know where I can get a manual for a porta-wire? I would appreciate any info.Pan
Reply:Thermal Arc hefty is a duplicate  of the Hobart feeder. You can get a copy of the manual from Thermal Arc website .Profax sells a replacement contractor #6431.
GMT+8, 2025-12-30 21:57 , Processed in 0.379153 second(s), 19 queries .
