humane society gate installed.
发表于 2021-8-31 22:35:41 | 显示全部楼层 |阅读模式
I also did the columns. Slate with broken glass and granite mosaics. Details placed with tweezers, pictures don't do it justice, and we're taken before grouting and sealing. Attached Images
Reply:Nice! What'd you use to cut out the dog and cat?Millermatic 211 Miller Blue Fire 140@swiftwelding on Instagram
Reply:All I have is a grinder and torch, I used a little of both.
Reply:The gate looks good but the columns look great! Really good jobsyncrowave 250Millermatic 211Fabricator 211iBobcat 250 EFI12VS Extreme24x40 shopSOME OF THE STUFF I HAVE BUILTwww.facebook.com/gowildfabhttp://www.gowildfabrication.com/
Reply:looks greatlife is good
Reply:wow, I'm even more impressed if you only used a grinder and torch... I've got a guy who wants me to make some cutouts of various wildlife from the area (middle TN) to weld onto the handrails of his boat... I've kind of been putting it off for a while because I didn't think I could do it with just a torch and grinder.....might just have to go for it and see how the first one turns out.Millermatic 211 Miller Blue Fire 140@swiftwelding on Instagram
Reply:Beautiful work!!!! Now as for billing the Humane society, I hope you charged them double!   They hate hunters and all things hunting.  "Hey I didn't come to look and learn, I came to turn and burn.... If I can't light up, I'm gonna light out!"-JodyIdealarc 250 "Fatman"MM 252MM 211 "Little boy" Victor Torches
Reply:Nice job.
Reply:Really Nice.  However, guess there is no Humane code.  I can see paws getting wedged or pinched.  I installed some infill panels underneath an existing handrail. The top of the panel and handrail are just ever so slightly off parallel  over 10 ft.  My youngest son stuck his hand in at the top and at the bottom couldn't get his hand out.
Reply:Originally Posted by tapwelderReally Nice.  However, guess there is no Humane code.  I can see paws getting wedged or pinched.  I installed some infill panels underneath an existing handrail. The top of the panel and handrail are just ever so slightly off parallel  over 10 ft.  My youngest son stuck his hand in at the top and at the bottom couldn't get his hand out.
Reply:Originally Posted by RobertGilliamAll I have is a grinder and torch, I used a little of both.
GMT+8, 2025-12-30 23:26 , Processed in 0.072774 second(s), 18 queries .
