Hobart Arcstar 251nt problem
发表于 2021-8-31 15:02:03 | 显示全部楼层 |阅读模式
So I have bought from auction a long standing Hobart Arcstar 251nt welder generator. Starts and runs very well, but doesn't weld or generate power on 240v sockets. What should be first things to look at. Thanks.
Reply:check the brushes on the slip rings. one might be stuck and not making contact.
Reply:From what I understand this unit is similar to the miller Bobcat 250NT , go to Millerwelds support and print a copy of the owners manual. follow the trouble shooting guide. https://www.millerwelds.com/support/manuals-and-partsMy old Hobart Champion 16 was doing the same thing, cleaned slip rings and found a cracked rectifier. replaced the rectifier and shes providing power and welding.https://www.westerbeke.com/troublesh...ing_manual.pdfI use this manual, because it shows how to test components with pictures of how to do it.
GMT+8, 2025-12-18 16:16 , Processed in 0.094226 second(s), 18 queries .
