My inexpensive welding table.
发表于 2021-8-31 22:35:39 | 显示全部楼层 |阅读模式
A few years ago I decided that I needed a welding table, but really didn't know how to proceed in building one. I looked at what some others had built to get ideas. I knew I wanted something portable. My wife went to a garage sale a few years prior and saw something she just knew I could find a use for, she bought it for $5.00....for a while it was used for clamps in my woodworking endeavors, but was ill suited for the task, too dang clumsy. But it would be the starting point for my new project. As you can see it was already on casters.Since my plans were to get a used Lincoln 225 stick welder I wanted the top of the table high enough to allow the welder to neatly fit underneath, so I cut the rack to the desired lengths and welded the one end to the framework. The only thing I had to buy was some 2" angle iron. I cut the pipes off the top and re-welded them on the lower portion along with the existing two others. My thoughts on this was they would make a nice place to hang C-clamps and pliers.The top cost me a case of beer, my farmer friend had what I needed and said when I brought over the case to stay and help him drink a few.....I borrowed my dad's welder for this project, since it is the same kind as I wanted to get I did a mock up of how it will set under the table. I'll need to make a hanger for the cables yet. When I told my dad I borrowed his welder.....he told me to keep it and he would come over to my place if he needed anything welded up. I learned to weld with this welder about 35 years ago when I was farming with him and my brother so this has added "sentimental" value.I am looking to find a vise for it yet. And as far as painting it goes.....it's in its working clothes now, whatever paint was on it is about all it's going to get. Hobart Handler 175Lincoln 225Rockwell 15-017 Drill Press
Reply:Nice job!! Welding is so much fun!!Hobart 125 EZHobart Handler 140Everlast STH 160Generic 210 Amp Welder/GeneratorHobart Air Force 500i plasma cutterChinese 50 amp plasma cutter! Youtube Channel : Henrymac100
Reply:I like it! Simple, cheap, and functional.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Nice lookin' job, Steve!! It should serve you well. Looks similar to the one I built several yrs ago. I just have two shelves under the top to keep all the little leftovers from projects and I usually find a use for most of them. As for the paint, no, mine hasn't ever seen any except for some overspray on the top from painting some small project.                                                            MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I was about 14 when I built my first one. I OA welded it out of used 3/4" pipe, and used a scrap of 1/4" plate on the top. I am up to 4" legs and 1/2" tops now, and looking at some 3/4" for the next one.
Reply:Steve safe simple efficient. Looks good. My grandfather had a Lincoln 180 amp welder that looked like your 225 amp.  He taught me how to weld in the early 60s with the welder.  Brings back old memories.  Happy to see your post
Reply:That'll work just fine.  Nice job.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Well done
Reply:I like it.  Nicely done.
Reply:Looks good!
Reply:Originally Posted by 7A749Looks good Steve Soon, you'll be building bigger ones....
Reply:Originally Posted by mla2ofusNice lookin' job, Steve!! It should serve you well. Looks similar to the one I built several yrs ago. I just have two shelves under the top to keep all the little leftovers from projects and I usually find a use for most of them. As for the paint, no, mine hasn't ever seen any except for some overspray on the top from painting some small project.                                                            Mike
Reply:Thanks for the positive comments fellas! Hobart Handler 175Lincoln 225Rockwell 15-017 Drill Press
GMT+8, 2025-12-30 21:55 , Processed in 0.100241 second(s), 18 queries .
