I don't know if anybody else on here does portable bore welding and line boring but I'm sure there are.... Here is a quick job i did on friday 2" holes....
Reply:Looks good. Expat does lots of line bore work on some of the heavy mining equipment. Looks good. What bore welder are you using?I use to do lots of that type of work on esco , P&H , L&H and several other shovel buckets. Left to work the gas line . Mis it once in a while did nothing but heavy mining equipment for 6 years ha ha made me get out some old pics.
Reply:So is a really professional way of saying that you put a spacer in, so the original fitting will work again. If so it looks like you did a great job and if not, well my bad.syncrowave 250Millermatic 211Fabricator 211iBobcat 250 EFI12VS Extreme24x40 shopSOME OF THE STUFF I HAVE BUILTwww.facebook.com/gowildfabhttp://www.gowildfabrication.com/
Reply:No he built up the hole with weld and then machined the hole back to spec. Looks like a good job with good equipment. I get by with a lot less sophisticated equipment just takes me longer. Here's a good thread where a guy made his own line boring equipment.http://weldingweb.com/vbb/showthread.php...ht=line+boring Here's a job I did a while back.http://weldingweb.com/vbb/showthread.php...ht=line+boring Here's another thread on line boring with some good info in it. http://weldingweb.com/vbb/showthread.php...ht=line+boringMillermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Originally Posted by irish fixitNo he built up the hole with weld and then machined the hole back to spec. Looks like a good job with good equipment. I get by with a lot less sophisticated equipment just takes me longer. Here's a good thread where a guy made his own line boring equipment.http://weldingweb.com/vbb/showthread.php...ht=line+boring Here's a job I did a while back.http://weldingweb.com/vbb/showthread.php...ht=line+boring Here's another thread on line boring with some good info in it. http://weldingweb.com/vbb/showthread.php...ht=line+boring
Reply:I have done mainly repair work but never watched the line boring setup until came to ww That was always done in shop and not one I worked forI have lathe and mill experience and would like to see it done one dayNice workSent from my SPH-D700 using Tapatalk 2Backed my CATMA over your CARMA oops clusmy me What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by killdozerd11I have done mainly repair work but never watched the line boring setup until came to ww That was always done in shop and not one I worked forI have lathe and mill experience and would like to see it done one dayNice workSent from my SPH-D700 using Tapatalk 2
Reply:Sounds like my kind of work expatThe indicateing in the bore doesn't look that hard I hav done that on small boring and sleeve back jobs on wornout machine parts on both lathe and millJust need to find a teacher or some place that does it some place closeSent from my SPH-D700 using Tapatalk 2Backed my CATMA over your CARMA oops clusmy me What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Expatwelder, correct it is spiral bore welded. Im saving up to upgrade to a climax system. Should have it this year sometime.Last edited by ttweld05; 03-10-2014 at 07:31 AM.Miller trailblazer302Millerxmt304millermatic 200lincoln squarwavelincoln SA250lincoln SAE400Climax BB5000
Reply:Good morning specopswelder, Im using a bore repair systems Bore welder, saving up to upgrade to a climax setup.Miller trailblazer302Millerxmt304millermatic 200lincoln squarwavelincoln SA250lincoln SAE400Climax BB5000
Reply:What does a rig like that cost?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11What does a rig like that cost?
Reply:This stuff is really cool. I always wondered how they align the bar if a hole is elongated.TOO MANY TOOLS & NO MORE SPACE
Reply:That's really cool. Nice job
Reply:Joker11, My whole set up cost me well over 20k. but that said.... I have 7/8" dia bars, 1 1/4" dia bars and 1 3/4" dia bars all different lengths from 2' To 8' I can weld from 3/4" up to 24" dia and bor from 1" up to 24" plus measuring tools, 30 ton ram and hydraulic power pack to press bushings in. Miller inverter and wire feeder to run the bore welder. a bunch of home made jigs and bearing supports..... The list goes on and on and onMiller trailblazer302Millerxmt304millermatic 200lincoln squarwavelincoln SA250lincoln SAE400Climax BB5000
Reply:Chris T, Very very carefully.....Miller trailblazer302Millerxmt304millermatic 200lincoln squarwavelincoln SA250lincoln SAE400Climax BB5000
Reply:That is a totally separate skill that requires pretty specific equipment. Looks like you know what your doing and have the goods to do it. I farm that work out to another guy. Its like 75% of his biz i think. Price is right and i know it will be spot on every time. Thumbs up!
Reply:Thanks TMW llc, Bore welding and line boring is all i would like to do 100% of the time but theres always something to do. As of right now its about 75-80% of my work. What does your guy charge if you don't mind me asking?Miller trailblazer302Millerxmt304millermatic 200lincoln squarwavelincoln SA250lincoln SAE400Climax BB5000
Reply:TMW llc, Also where a bouts are you located?Miller trailblazer302Millerxmt304millermatic 200lincoln squarwavelincoln SA250lincoln SAE400Climax BB5000
Reply:I am about 20 miles outside of Philly. We work a price out per job. Really depends on the size of the bore,the amount of holes, how bad it is worn ect. Can be as low as a few hundred a hole and up into the thousands.
Reply:TT,When you are ready to upgrade, drop me a email, I'm in the market for a bore welder. chaviswelding at yahoo.comReally nice work by the way. I woud like to talk with you more about pricing. I'm way under what Cat charges, but, customers still b#tch about the cost.
Reply:will do machavis!! Thanks for the reply Miller trailblazer302Millerxmt304millermatic 200lincoln squarwavelincoln SA250lincoln SAE400Climax BB5000
Reply:Originally Posted by TMW llcI am about 20 miles outside of Philly. We work a price out per job. Really depends on the size of the bore,the amount of holes, how bad it is worn ect. Can be as low as a few hundred a hole and up into the thousands.Originally Posted by DSWDepending where you are in my neighborhood. I'd love to see it done some time if you are doing a weekend job.
Reply:ttweld, Thanks for posting. There is a lot of interest here. If you do not do this type work at your job, then the tools and equipment is pricey. For your regular welder, hobbyist and DIY Guy making a line boring set up is possible. But the bore welder is not. Personally have great interest and have slowly bought some tools . So far have a Mag drill and a hydraulic hole ram and as time and money permit will fab a boring bar. The real challenge will be to get a bore welder or make a DIY bore welder.
Reply:I'm in Bucks up near Warminster. Yeah if it comes up, let me know and I'll see what my schedule is like..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWI'm in Bucks up near Warminster. Yeah if it comes up, let me know and I'll see what my schedule is like.
Reply:Thank you guajilloweld03, It is very possible to build your own set up. I only have a couple bearing supports that came with my set up and everything else is home made by me. Every job is different. You need to be smart and think how to adapt what you have to make it work on what you need to weld/bore.... Miller trailblazer302Millerxmt304millermatic 200lincoln squarwavelincoln SA250lincoln SAE400Climax BB5000
Reply:Originally Posted by ttweld05Thanks TMW llc, Bore welding and line boring is all i would like to do 100% of the time but theres always something to do. As of right now its about 75-80% of my work. What does your guy charge if you don't mind me asking?
Reply:Shameless profiteering Everyone here thinks I should weld ther stuff for the privalige of it and supply consumables and fuel tooSent from my SPH-D700 using Tapatalk 2Backed my CATMA over your CARMA oops clusmy me What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Killerdozer-------where are you located in Cali? I will be in the Merced area around the 28th of March, I have one appointment then I plan on just cruising around for a few days "exploring".......if you are anywhere close maybe we could meet for a beer or 3..6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:I am way down south in west Hemet ca / Winchester areaIn Riverside countyI got called Sunday to run a scraper so I'm back to moving dirtExcept for the guy I was teamed with.. Stuck over the edge 3 times. Bye byeSent from my SPH-D700 using Tapatalk 2 Attached ImagesBacked my CATMA over your CARMA oops clusmy me What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck |
