Wanted: Lincoln MIG Owners
发表于 2021-8-31 22:35:35 | 显示全部楼层 |阅读模式
A research company is conducting a welding-related end user meeting on May 24th, 2006 in the Baltimore, Maryland area. The purpose of the meeting is to understand user needs for future welding products. The discussion will last approx. 90 minutes and you will be compensated $200 for your time.To qualify for participation, you must own one of the following Lincoln welders and live in the state of Maryland. Please select the unit(s) you own.  Lincoln SP175T or 175 Plus Lincoln Weld-Pak 5000 HD Lincoln Pro-MIG 175 Lincoln Power MIG 200 Lincoln Power MIG 215 Click the following link to register ...www.surveymonkey.com/s.asp?u=448522112598
GMT+8, 2025-12-30 21:55 , Processed in 0.138146 second(s), 18 queries .
