Welder advice needed
发表于 2021-8-31 22:35:31 | 显示全部楼层 |阅读模式
This is the stick welder I just got. I want to make sure I run it correctly so I need advice. I am not sure if I am supposed to insert the upper leads into the bottom unit and the the electrode and ground welding cables into the upper unit or leave it like it is and insert the welding cables into the lower unit. I am not sure why there is an on/off switch on both upper and lower either. Can anyone give me operating instructions on this unit, thanks
Reply:Never seen one of those. Some closer pictures of the labeling under the ON/OFF switch might help get some more opinions though. Looks well taken care of and very interesting!SA-250 TMDSquarewave 200Thunderbolt AC/DC1951 G.E. welder
Reply:Bottom unit is probably an AC welder. Plug one lead into the A, B or C receptacle up top and lead 2 into the numbers receptacle below to get a certain amp range. Top unit may be a DC rectifier. I believe you plug those leads into the receptacles below and your welding leads into where it says electrode/ ground.Clearer picts of the writing on both units would verify if this is what I think it is..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I'm with DSWIt looks like you have 15 different amp settings, depending on which combination you use with the built-in plugs.Maybe like a, b, c = low, med, high - and within each of those, 5 different finer settings....or vice-versaHobart Beta-Mig 2511972 Miller AEAD-200LEMiller 250 TwinNorthern Ind. Hybrid 200Longevity Stick 140Longevity Migweld 200SThermal Arc Pak 3XR
Reply:I think the top unit is a high frequency rather than a rectifier. I had read in the past about Midstates high frequency units to make striking and maintaining an arc easier on AC.
Reply:Originally Posted by geezerbillI'm with DSWIt looks like you have 15 different amp settings, depending on which combination you use with the built-in plugs.Maybe like a, b, c = low, med, high - and within each of those, 5 different finer settings....or vice-versa
GMT+8, 2025-12-30 21:55 , Processed in 0.100625 second(s), 18 queries .
