Mtaw?????????????
发表于 2021-8-31 22:35:31 | 显示全部楼层 |阅读模式
Anyone heard of MTAW, as opposed to GTAW?I am quoting a part that lists MTAW as an alternative on stainless 316 alloy. TIAWeld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:What does the M stand for?
Reply:Are you quoting some parts for a train or bus?......Mass Transit Arc Welding
Reply:Only 1 Google hit :      Metal Tungsten Arc WeldingBut I don't think it is correct.Century buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:Metal Tungsten Arc Welding I think it's a British thing, same thing different words.
Reply:Hello shovelon, so I haven't heard of that particular acronym. Do you know what it stands for? If I were to take a guess maybe: "Mechanized Tungsten Arc Welding", but that is just a guess. Kind of like how the europeans use MMA to denote the SMAW process. Best regards, Allanaevald
Reply:I saw this in an aircraft welding publication from Australia (page A9):(apparently a MIG process)For oxy-acetylene (gas), GTAW (TIG) and MTAW (MIG) welding processes,examination metal thickness of sheets is 1.6mm thick (this will include material of0.063 inch thickness). http://www.casa.gov.au/wcmswr/_asset...worth/33_1.pdfDave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:And a college welding course in Texas:The program includes entry-levelskills in stick (SMAW), oxy-acetylene (GAS), gas shield arc (GTAW andMTAW) and flux-cored arc (FCAW) welding. There is a $200 supplyfee per class and a one-time investment of approximately $150 forpersonal equipment.
Reply:Ok, then I think they must mean mig weld. I quoted the job as tig weld so I am good to go. Thanks.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:MTAW = Miggy Tiggy Arc WeldingMunching Tobacco And WeldingMetal Touchy Arc Welding"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:??Mig like Tig Arc Welding?? as seen on welding web?Mike
Reply:I found it. Mr. Tig Arc WeldingWeld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Shovelon, I almost posted that.  But I already picked on him once this week, so let it go."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by OldendumShovelon, I almost posted that.  But I already picked on him once this week, so let it go.
Reply:One drop at a time.  Monkey TIG Arc Welding!!!"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I think there's a sticky on of these forums... MIG like TIG arc welding. They also use the term MAG welding overseas for Metal active gas (Co2 shielded)
GMT+8, 2025-12-30 21:55 , Processed in 0.108675 second(s), 18 queries .
