just ordered from lehigh valley abrasives
发表于 2021-8-31 22:35:29 | 显示全部楼层 |阅读模式
well i just placed an order for 20 ceramic grain flap discs they came in at $2.25 apiece  total with shipping$59.00 and since he sells them however you like i got 5 in each grit to try 40,60,80 &120 im going to use them on a up coming project ill report how they do350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:I like mine i got from them....BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:How do you like the 40's, do they keep they're aggressive edge ?Anything worth doing is worth doing RIGHT
Reply:well seeing as i haven't been on with anything to post about since my welding space was turned into storage for a bit. ive finally got it back and thought i would update this thread ive used these discs for quite sometime on various projects and i can definitely say they are great discs at a great price and well worth a try i know i wont be buying discs from anywhere else again 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:what sort of advantages do the ceramics give over conventional discs?
Reply:Originally Posted by jakeawhat sort of advantages do the ceramics give over conventional discs?
Reply:I've been using the 2" Norton Blaze abrasive discs for the past year or so, they are ceramic.They do cut a bit faster, last a bit longer, and run a bit cooler than the regular kind, but they load up quickly on aluminum. But then, what doesn't.And I can't speak for other brands, but the Norton's are also safe and of a high quality. I haven't had a single one fire off or shred. The backer seems much stiffer than usual, and the edge of the disc wears cleanly so you can grind on pointy stuff without shredding the disc. Nice.The 36 grit is voracious, but the scratches take quite a bit of time to sand out with my typical 80/120 paint prep routine. 50 is a good compromise, but they definitely don't last as long as the 36.I do use the Blaze on aluminum, even though Norton makes aluminum specific product. I just use a fine wire brush to knock the aluminum off the disc before it gets out of hand. But with poor technique on aluminum, a dumbass operator can reduce the efficiency of the disc by half in less than two minutes, so....YMMV(your mileage may vary)
Reply:Originally Posted by bert the welderX2Are they plastic-backed or that black resin stuff?Just got some blue, plastic-backed ones by Jet, 60 grit. Haven't tried them but they where $7, half the $ of the Walter ones. So yours, if good where extra super cheap!I like the plastic-backed ones because you can carve back the plastic to get an exposed edge.
GMT+8, 2025-12-30 21:54 , Processed in 0.142925 second(s), 18 queries .
