BOC welding wire speed adjustment
发表于 2021-8-31 22:35:21 | 显示全部楼层 |阅读模式
Hi guys,I own a BOC smooth arc advance 200C MIG welder. Im wondering if any of you'se Know how to change the wire speed individuly as i can only have it change buy either up'ing or down'ing the volts in comparison to the wire speed.Any advise will be appreciated.thankschad snyds
Reply:Hey snyds, try toggling the left hand menu (volts/wire feed/inductance) until the wire feed light illuminates, then roll the knob.should be that simpleJ45+ years of accumulated fabrication junk - both physical and mental.....  occasionally some of it is vaguely useful.
GMT+8, 2025-12-30 22:51 , Processed in 0.097824 second(s), 18 queries .
