Need to weld the handle on the drill press onto the cast iron thing it screws into.
发表于 2021-8-31 22:35:20 | 显示全部楼层 |阅读模式
The drill press at work needs one of its handles/arms/levers welded back on.  They normally just screw into the cast iron part but the threaded hole is all flogged out.  I don't have any cast iron welding gear, but I think I have like a 312-16 stick rod.  Will this be good enough to hold it on.  It wobbles like a jelly fish at the moment, so if I could get a bit of weld to stick and just hold it in place it should be good enough.We have a tig, but I still think I would need a special filler to joint the mild steel and cast iron?  I have standard 316L rods for the tig only.  Seem to think that there is a dissimilar metals rod you can use to join metal that you don't know what it is.  I think it is similar to the 312-16 that I think I have.  Maybe if I was to get rid off the flux off the stick electrode and then tig weld it using that stick electrode as the filler?
Reply:Heli coil.                                         MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Heli-coil or braze it.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:or drill it out and tap it biggerMiller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:What they said if not maby jb weld or something similar then you would not have to weld it.
Reply:Helicoils are easy to try first. Or braze it, that would be my first choice. Failing that, JB weld. Not worth trying to weld if you don't have the right gear. You can use the tig to braze it, or oxy/fuel torch.
Reply:I agree with what they said.  Try to avoid spending $400.00 time on a $2.00 job.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:If only I had learned that at a younger age! Originally Posted by nadogailI agree with what they said.  Try to avoid spending $400.00 time on a $2.00 job.
GMT+8, 2025-12-30 23:16 , Processed in 0.135871 second(s), 18 queries .
