weldable chain Q
发表于 2021-8-31 22:35:19 | 显示全部楼层 |阅读模式
Need to stick weld some links of plain steel chain together.  Links would be about 1.5" long.  Q. is what sort of chain can this be done with.  The galvanized stuff commonly sold in marine places wouldn't be a good choice, nor obviously would the chain coated with white vinyl.        -Marty-
Reply:You can buy plain, un-plated steel chain at Tractor Supply and some box stores. In this case, the cheaper the better. Higher grades of chain contain high levels of carbon and are more likely to crack when welded.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:as long as your not planning on using this welded chain in a load carrying manner, any cheap hardware store chain should work, most will sell it by the foot or the pound.
Reply:I can't tell you how many endless chains I've welded together over the years to handle wire rope. I always asked of 309 stainless steel rod to make the welds.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Find a commercial garage door installer, they usually have buckets of unwelded chain that they will give away.Miller Dynasty 200DXMiller 252 Miller 250xMiller Syncrowave 250Miller AEAD200 LegendMiller 375 Xtreme plasmaLincoln WeldPak 100Victor O/A
Reply:Not sure if these help you, but I have been using these for years at work on some heavy duty equipment at work. Here's a link to there site.http://www.tulsachain.com/?gclid=CJ_...FTHNOgod1UgA0Q I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:When you deal with bigger chain these work well too. http://www.cometsupply.com/mp/ACCO/p...94201201/r/ga/Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Thanks for the good info, guys.  Much appreciated. -Marty-
GMT+8, 2025-12-30 22:58 , Processed in 0.118157 second(s), 18 queries .
