Saltwater Reel Spooler
发表于 2021-8-31 22:35:16 | 显示全部楼层 |阅读模式
As I was replacing some of the line on my fishing gear this past weekend, I quickly realized how frustrating is it to hold a reel/rod and while balancing a reel spool between my feet.  All the while trying to hold tension on the line. As the spool was rolling around the room, I knew what I was about to build.  REEL SPOOLER.  As this is my 2nd project with a welder.  Cart being 1st.  Can't wait to give it a try.  Only thing it needs is a way to mount a drill to the side of the reel to make it motorized.  Ideas?
Reply:Should work, are you going to add a way to apply drag to the spool so you can wind the line on tight? With mono winding on tight isn't a problem, just don't get as much line on the reel if its a little loose. With spectra lines it needs to be spooled very tight to prevent the line from digging into itself and breaking.When I spool my reels with fresh line I push a piece of rope through the spool and tie each side to table-chair legs. Keeps the spool from dancing all over the room. If I'm spooling with spectra I put another rope under the first with a rag over it and tape it in place to add drag. I will add a picture of my setup if you want.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
GMT+8, 2025-12-30 23:09 , Processed in 0.102710 second(s), 18 queries .
