Truck Crane Project
发表于 2021-8-31 22:35:16 | 显示全部楼层 |阅读模式
Well I am getting to old to dead lift heavy objects onto the back of my truck. So my old man had this Star Machine and tool crane lying around for at least 30 years. The tag on it is 1968. He used this on the back of his truck to lift real Cummins engines and huge transmissions out of tractor trailers. This model will lift 2 tons. It has an air over hydraulic pump. I need to modify the mount for my truck and add some bracing under my flat bed. I will also need to make a pin locking device (because my bed dumps) for the bed as well as a support jack set up. I have a small compressor already and a tank in my tool box. I am going to sand blast and paint this thing. He also made an extension arm. I have to find a pic where he has it in use on a 48 chevy flatbed welding truck. This will also aid me when I pick up steel plate from the metal supply.Here is the site:http://www.starmachinetool.com/floorcrane.htmwww.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Nice. That cylinder is beefy.
Reply:Wow you can tell that cylinder was built to do the work.   Seeems like I saw one just about like that at Harbor Freight.................lol. Good luck on the hoist.  Those things are really handy.
Reply:Originally Posted by richeyWow you can tell that cylinder was built to do the work.   Seeems like I saw one just about like that at Harbor Freight.................lol. Good luck on the hoist.  Those things are really handy.
Reply:that looks sweet. keep posting pictures of the progress.Miller trailblazer 251Miller Spectrum 625Millermatic 2511970 Lincoln SA-20010lb sledge hammer
Reply:Interesting project, keep us updated. I noticed that when your father retired the crane he closed it (by the rust track on the pin joint) to minimize its size and also to protect the piston from rust saving the crane for future use.  Bob
Reply:Great find and I wish it was mine. have you tried it yet? I wonder how much air that pump takes.
Reply:That hose looks spent.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Originally Posted by rhuntInteresting project, keep us updated. I noticed that when your father retired the crane he closed it (by the rust track on the pin joint) to minimize its size and also to protect the piston from rust saving the crane for future use.  Bob
Reply:Haven't got back to this project yet as I am working on getting my CNC plasma table up and running in the next month or so. I will get back to this soon.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:chevydyl, look at the second picture.  The hinge point.  Check the rust trac.  Bob
Reply:Yeah I see what your talking about. But the correct term is rod.....the piston is inside the bore and can be seen unless disassembled. However the rod was collapsed during storing which kept rust from forming on it. I bought a used plow that was left angled and the rod was rusted but there was also rust inside the bore that ruined the seals on the piston which allowed fluid to leak into the wrong chamber and therefore the hydraulic mechanism no longer worked.According to meyer snow plows the best way to store hydraulic cylinder is fully extended that way the bore is full of oil and cant rust from condensation then you need to cover the rod in oil or by some other means of protecting it.Last edited by chevydyl; 03-20-2014 at 04:43 PM.Miller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:Ive got one just like that! I've been wanting to fix it but haven't started yet. Can't wait to see yours finished! Keep us posted! Miller trailblazer301gLincoln sa200Miller251Miller spectrum 625Victor oxy-acc2002 Chevy duramax 3500 dually 4x4
GMT+8, 2025-12-30 23:09 , Processed in 0.114168 second(s), 18 queries .
