Hi,i have a sp 100 mig welder by lincoln and i am having problems with the machine, it runs the fan but no gas and or feed of line, the manual says it will reset on its own and i tried the manual reset inside the machine and this doesn't work either does anyone have any suggestions.thnks
Reply:It sounds as if your trigger switch isn't working properly. Open the side of the machine and make sure that the gun trigger terminals are connected to the machine. If they are connected, I'd then pull the gun apart and test the switch with an ohm meter.- Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:thanks paul i will give that a try |
