Seeking MIG drive roller: 35mm OD
发表于 2021-8-31 22:35:10 | 显示全部楼层 |阅读模式
I have been searching for drive rollers for my Dip-Pak 200. I want a roller for .035/.045 wire. No luck.I now am now looking into modifying a roller used in some other application, and would like to develop a list of machines which use 35 mm OD rollers. Any help would be appreciated.BTW, my dimensions are 35 mm OD, 9 mm ID, 13 mm thick, with a keyway.Thanks,RoyAirco DIP-PAK 200
Reply:I have a thermal arc 190 w. 035/045 the id for keyway is 10mm, my quess is your best bet may be just have one machined to suit your needs from an existing roller. Best Sent from my SGH-I747M using Tapatalk
Reply:See if Profax may have drive rolls.
Reply:Originally Posted by pistolnoonI have a thermal arc 190 w. 035/045 the id for keyway is 10mm, my quess is your best bet may be just have one machined to suit your needs from an existing roller. Best Sent from my SGH-I747M using Tapatalk
Reply:Originally Posted by Welder DaveSee if Profax may have drive rolls.
Reply:Sorry, my apologies I mistyped id is 10mm, 035/045 drive roller Sent from my SGH-I747M using Tapatalk
Reply:Sure...10 mm ID. Is the OD = 35mm?RoyAirco DIP-PAK 200
GMT+8, 2025-12-30 23:17 , Processed in 0.098152 second(s), 18 queries .
