Help me pic a compressor
发表于 2021-8-31 22:35:04 | 显示全部楼层 |阅读模式
well i wanna replace my lil 20 gallon with a 60 single stage about 700 is my limit and i wanna get the best for my buck i will list my choices and hopefully those of you more in the know will help me out hd/lowes 10.2 @ 90 4 HP  $429 http://www.lowes.com/pd_102750-1126-...ntity_sold%7C1  iron horse 11.2@90 6.5hp $629 http://www.aircompressorsdirect.com/...sor/p5489.htmlpuma 12@90 3hp $629 http://www.aircompressorsdirect.com/...ssor/p591.htmleagle 12.5@90 5hp $719 http://www.aircompressorsdirect.com/...sor/p5515.htmlingersoll rand 10.3 @135 3hp $569 http://www.google.com/product_url?q=...=0CCQQgwgwADgAright now for the cfm im leaning toward the eagle first iron horse second there made by the same company but i will have to order them but with free shipping and no tax i save some cash then the puma but the 3 hp seems a lil small  as for use its just me in the shop so i only use one thing at a time so 60 should be big enough  since i cant look at the last three i was hopeing y'all would have some feed back thanks for any helpLast edited by umahunter; 12-11-2010 at 01:49 PM.350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:I'd recommend checking out Tractor Supply.They have a nice 3HP/60 gal tank unit made by Ingersoll Rand.  I've found that Tractor Supply has much better prices on their Ingersoll Rand air compressors than Northern Tools.  I just bought a 5HP/80gal, two stage compressor from them and it was $350 cheaper than from Northern.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:yup i looked at that but its in stores only and they dont even have a store in az or anywhere even close added to the list theyve got it at northern for 569Last edited by umahunter; 12-11-2010 at 01:50 PM.350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Which ever you choose I would advise to get a disconnect switch like this. I bought an IR comp from HD and the plastic switch on the unit failed and it ran all weekend with the drain wide open. I returned it."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:The IR is rated at 135psi.  I wonder what cfm it puts out if it's only pumping to 90? It should be a little more, maybe not enough to beat the 12.5.  I don't know.  It would be nice to compare apples to apples though.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:i looked in an old catalog and it has the IR listed as 11.3 @ 90 but there's not really much info on it the 5 hp is listed as 100% cast iron cylinder but no info on the 3 the others i was looking at like the eagle have the newer v style cylinders instead of the I350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Northern has the IR 5HP, 60 gal tank, 18.1 cfm @ 90psi for $889 and FREE shipping.I prefer the Ingersoll Rand name over any of the compressors you've mentioned.Even better is the Quincy, but they don't have a machine that meets your needs.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:My vote is for the IR the homey depo compressor won't really hold up as well. Never really heard or had any dealings with the other brand.Vantage 300 kubota ,miller 304 xmt ,lincoln ln 25 pro , ranger 305 G, plenty of other tools of the trade to make the sparks fly.
Reply:This compressor may be another option for you.  http://www.lowes.com/pd_221565-14989...&storeId=10151155psi max,  13.3scfm @ 40psi, 11.5scfm @ 90psi, 3.7 running hpA few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:my biggest concern with the ir is that from what ive read the newer v style run cooler and quieter then the i style since it will be outside in the summer az sun i will build a house for it but it will still get to 110 -120 in the summer my second concern is the spot where i will have to put it is about 20 ft from the neighbors back door so i will need to try and somewhat soundproof the lil house to lessen the noise350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Originally Posted by umahuntermy biggest concern with the ir is that from what ive read the newer v style run cooler and quieter then the i style since it will be outside in the summer az sun i will build a house for it but it will still get to 110 -120 in the summer my second concern is the spot where i will have to put it is about 20 ft from the neighbors back door so i will need to try and somewhat soundproof the lil house to lessen the noise
Reply:tractor supply has a 60 gal campbellhausfield oillubed compressor twincylinders  3hp 230v  for $ 399  ..good reviews if youre not looking for  a cadillac...
Reply:Originally Posted by Crawfordspray foam insulation for the win.
Reply:Originally Posted by gimpyrobbIf you seal the housing up too much, how will it dissipate the heat it creates? I have mine in a shed with openings in the bottom and the top. That allows the heat out at the top and cooler air in the bottom. It might not be a concern for most guys, but I use a LOT of air sometimes and it is a concern for me. The compressor in a shed makes a big dent in how much noise there is. Also, a single stage compressor with 2 pistons makes more cfm than a dual stage with 2 pistons.
Reply:I bought a Craftsman reconditioned 60 gallon, 3.2 RHP compressor last month for $270 out the door. Only time will tell how it holds up but for now it seems like I got a good deal.
Reply:i went with the IR 3hp 60 gal #ss3L3 buy the start up kitand get a 2 year want. great comp. i bought it fromnorthern tools $599.00 free shipping Attached Images
GMT+8, 2025-12-30 23:44 , Processed in 0.103569 second(s), 18 queries .
