Parts Washer
发表于 2021-8-31 22:35:04 | 显示全部楼层 |阅读模式
I'm not sure if this is the right section for this, but I'll try.I bought a Snap-On parts washer from a guy I work for part time.  It was sitting in the corner of this shop untouched for a year and a half, so he finally let it go.Does anyone know an online source for the barrel liners?  According to the instructions you  get a plastic liner, like a garbage bag, but it needs to be chemical resistant.I tried contacting a Snap-On rep through their website, but I never got a response.  I haven't seen one on the street I can flag down in a while now either. Attached Images
Reply:might check with saftey-kleen if you can't get in touch with snap offidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by brendonvDoes anyone know an online source for the barrel liners?  According to the instructions you  get a plastic liner, like a garbage bag, but it needs to be chemical resistant.
Reply:I am going to use kerosene, I was just nervous it'd turn the garbage bag into a broken down glob of goo.
Reply:Usually, if you go to your local auto shops, you can get the phone number for the snap-on driver in the area.  Just give him a call directly and they'll take care of you pretty well.  At least that's how I get any Snap-On items that I need --Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:These are called drum liners:http://www.mcmaster.com/#barrel-liners/=a5cbia
Reply:Wow, Not sure why I didn't think mcmaster.  Thanks
GMT+8, 2025-12-31 01:32 , Processed in 0.072137 second(s), 18 queries .
