查看: 13|回复: 0
Very cool lathe RPM indicator.....
发表于 2021-8-31 22:35:03 | 显示全部楼层 |阅读模式
http://www.gizmology.net/lathetach.htm
Reply:I'm guessing he's young enough to never had to use a timing light on an engine. .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Nice way to go for a lathe.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Timing lights show the position of the crankshaft timing mark relative to the #1 cylinder spark pulse.  Most older timing lights do NOT show RPM.  For that, you need a tachometer.  Back in the day, you could get one for under $30.Seems you can still get them for about that price.  These are inductive pickup units, so you only need to clip the probe around a sparkplug wire.  These are for 4-6-8 cylinder engines.  For engines with fewer cylinders, you do some mental math to get the speed or you use a photo tachometer (see below). http://cgi.ebay.com/ebaymotors/17208...item2eb14dc9c5http://cgi.ebay.com/ebaymotors/INDUC...item43a10763fdThe alternative is a phototach, which counts light reflections (usually from a piece of shiny tape) on a moving part of the engine.http://cgi.ebay.com/ebaymotors/HQRP-...item5196d086a8John
Reply:Cool idea Back in the 70's I was a FE for a computer company that is how we set the speed on magnetic tape machines.  There was a black and white disk on the capstand you would look at it and adjust a pot for the correct speed. The flicker from the fluorescent light will act like a strobe light and sync with your pattern for speed checks.have funtom
Reply:And all these years I was taught not to use florescent lights in the shop so the spinning tools didn't look like they were not moving.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Or for $25.00 to $250.00 you could get a phototach and use it everything is the shop. http://www.amazon.com/Electronic-Spe.../dp/B000RFK50S"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Originally Posted by DSWI'm guessing he's young enough to never had to use a timing light on an engine.
Reply:I would make it out of a basic stamp. Pretty simple stuff here:http://www.parallax.com/Default.aspx?tabid=420
Reply:Old teletype machines were adjusted by looking at marks through a vibrating tuning fork.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
GMT+8, 2025-12-31 01:31 , Processed in 0.070178 second(s), 18 queries .
