Shield Gas Setting - MillerMatic 211
发表于 2021-8-31 22:34:58 | 显示全部楼层 |阅读模式
Just curious as to what a "generic" AR/CO2 setting would be for my MM 211? Any other tips are appreciated!
Reply:I set mine around 20-25No other advice or tips...Just pull the trigger...Autoset seems to be pretty accurate.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:I run mine at 20 - outside light breeze maybe 25The main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:Originally Posted by MrBelvedereJust curious as to what a "generic" AR/CO2 setting would be for my MM 211? Any other tips are appreciated!
Reply:Originally Posted by MinnesotaDaveIsn't that written on the door chart?
Reply:Originally Posted by Broccoli1Miller buries that sheite in the manual under Installing Gas Supply and uses confusing words like "Typical""Gas Flow Adjustment ControlTypical flow rate is 25 cfh (cubic feet per hour)."
GMT+8, 2025-12-31 01:32 , Processed in 0.098541 second(s), 18 queries .
