Can anyone tell me who made this old Craftsman torch and what type tips work on it?
发表于 2021-8-31 22:34:56 | 显示全部楼层 |阅读模式
Can anyone tell me who made this old Craftsman torch and what type tips work on it?  Got it in a trade with a friend.  I bought new (used) gauges to replace his. Attached Images30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Sears Craftsman tool prefix of 313 comes up as Harris.  The angular "hood" on the business end of the cutting attachment is distinctively Harris.  Which one and which tips it takes are open to question.  But you have a good start."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Thanks.  I'd like to make use of this torch and don't want to buy junk/wrong items.  Sears parts is no help, even for an owner's manual, which I would dearly like to find.JerryLast edited by storeman; 02-07-2014 at 07:12 PM.Reason: spelling30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Harris is a good start.  Thanks for the info.  I'll look for a way to contact Harris about .5" tips smooth to the flange.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Does anyone recognize the tip shape?  Seems different from the ones I see available today.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:It's a Harris. I've got one or two just like it. Good torch. You can still get kits for them.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:Thanks, What size Harris? Where would you recommend I look?  Our local welding supply closed some time ago.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:The cutting tip looks similar to the Harris 6290 type tips, but the mounting flange is much thinner on yours. In looking at tips, it seems some of them are two piece, with an inner brass insert and a copper outer shell that looks identical to yours (like this). Does your tip fit properly in your torch? If not, perhaps part is missing? Photos or the mating faces of the torch and tip would be very helpful.
Reply:These help?  The tip fits properly.  I don't think anything is missing.Last edited by storeman; 02-08-2014 at 06:05 AM.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Could the Harris 2490 tips be the ones?  https://atlweldingsupply.3dcartstore...ips_c_667.html"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Looks like the one I use
Reply:Originally Posted by OldendumCould the Harris 2490 tips be the ones?  https://atlweldingsupply.3dcartstore...ips_c_667.html
Reply:ATL Welding seems to have some funky old stuff.  I think they've been around long enough to know a thing or two.  You could always call them and see if they know their stuff.  The newer 6290 Harris tips seem to have a similar seat, but are taller where the nut goes.  An adapter nut is available to use the old tips with the newer torch.  Not sure if there's a solution for the other way around. But if you can get the old-style tips for $5. each, who cares.  Get a handful."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I agree.  Will do.  Thanks.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
GMT+8, 2025-12-30 23:43 , Processed in 0.099747 second(s), 18 queries .
