Honu: MagDrill SOF
发表于 2021-8-31 22:34:55 | 显示全部楼层 |阅读模式
"Honu" MagDrill SOF (stand-off fixture). 1/2" and 1/4" A36 HRS.  Custom design/build to interface a Hougen 904HMD (non-swivel base) MagDrill for a client ("Milkerman") in MI.  "Honu" supports the use of annular cutters and twist drills on pieces affixed to top -or- bottom of the work surface.  Pleased on the outcome and finish of S/N 001.  Made a minor fastener adjustment to the base sub-assembly thanks to Milkerman's input.3D Modeling (FormZ); Plasma Cut (Hypertherm PowerMax 45, Quincy 2-Stage 60Gal Compressor); Drilling/Transferring/Threading (Jancy Slugger Holemaker II MagDrill, MA Ford Uniflute, Spellmaco, Norseman, Starrett); Fastening (McMaster-Carr, SHCS Fasteners, BlackOxide); MIG Axial Spray (Miller XMT304); Surfacing/Grinding (Metabo), Finishing (PowerCoat, 1-stage, FigureFinishing, Manassas Park, VA).Special Mahalo to Len McCreary and Christine at FigureFinishing, LLC for their outstanding powder coating services and professional client relations.  Top-tier.  Designed & Built in USA. Attached ImagesLast edited by ManoKai; 03-16-2014 at 09:19 PM.Reason: syntax"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:That is really nice, I like the finish they put on it and the design/fabrication is top quality. If I had my mag drill I'd be in line right now to get one, do you have any plans on making other fixtures like a pipe clamping base? Just curious what the little round piece with the shcs is? I'm sure he will be very happy with this.TOO MANY TOOLS & NO MORE SPACE
Reply:That's a good piece of equipment that you have built. Impressive
Reply:I'm trying to find the coupon to get one of these, because I just bought a Hougen 904HMD!!!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I am waiting for the introduction of on for the Hougen 914 with a swivel base....Mike
Reply:Holy cow! Nicely done!  Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:ManoKaiNicely done - it will look good at a trade-show.What does it actually do - so it doesn't get ugly in service?Opus
Reply:mano; nice build and beautiful finish. i must be missing something but wouldn't the plate that the tool goes through obstruct a center punch or reference mark? would that fixture work without that plate?i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docweldermano; nice build and beautiful finish. i must be missing something but wouldn't the plate that the tool goes through obstruct a center punch or reference mark? would that fixture work without that plate?
Reply:Mahalo loa nui to all for your professional comments.  The design/build required a substantial amount of preparation, testing, and fabricating.  S/Ns 002 and 003 are in the worx and have a few additional features/upgrades.@ Chris T - the circular fixture aft of the drill's magnet is a safety featuring providing longitudinal "lock-in" in the event of electrical power disruption.  The fixture, born of the slug from the large hole in the work surface slug, was hand-turned on a Metabo bench grinder to the correct OD.  The slug's SHCS is set with eccentricity relative to the face.  Similarly, traverse "lock-in" is provided by the 2ea black oxide holding clamps on the drill magnet's left/right face.  Pipe and tubing fixtures are also built and ready for integration.@ docwelder - the work face's thru-hole is indexed to the mag drill's arbor (cutter) centerline.  Manufacturer-specific.  The relative coordinate system for the design is based on this centerline measurement.  There is adequate surface area in all three axis of the work face to allow centering/marking/punching, in addition to affixing a work piece to the surface via welder vice grips or C-clamps.  Note:  The above image, showing a Jancy Slugger Holemaker II MagDrill w/ a keyed Jacobs chuck arbor and 7/16" twist drill, is a marketing photo. By design, the front face of the MagDrill's base is ~ flush to the interface plate's front face.  The Hougen and Jancy have different arbor (cutter) centerline distances, hence the offset shown with the Jancy integrated to a "Honu" built for a Hougen.@ Stick-man, leightrepairs - the "Honu" SOF's design is flexible and scalable.  Easily configurable to Hougen (swivel, non-swivel), Jancy/Fein, Metabo, Milwaukee, Evo, and Nitto magnetic drills.  Send PM for inquiries.Last edited by ManoKai; 03-17-2014 at 03:22 PM.Reason: syntax"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Nice work Mano. I love the powder coat. What does the whole thing weigh now? Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:@ Robert Hall - Net weight of 42lbf."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Very nice work!
GMT+8, 2025-12-30 23:43 , Processed in 0.097576 second(s), 18 queries .
