does anyone have any hardfacing pics?
发表于 2021-8-31 22:34:52 | 显示全部楼层 |阅读模式
I live in a farming community and I do a fair amount of repair work but havent been faced with hard facing or re surfacing cultivator shanks or plow shares.  i was given some hardsurface rod not to long ago and I have some old shanks I might try and practice some but does anyone have any experience in this and any techniques ?Miller Bobcat 255Hobart 190 and spoolgunLincoln AC 225Lincoln LN-25Rock and Roll hoochie coo
Reply:Here's the link to Lincolns Hardfacing PDF.http://www.lincolnel...ature/C7710.pdfHere's a PDF from Stoody listing agricultural implements.http://victortechnol...1)_July2007.pdf A few other Stoody PDF's on hardfacinghttp://victortechnol...2A)_Oct2012.pdfhttp://victortechnol...20)_May2012.pdf http://www.stoodyind.../05catpg356.pdfhttp://www.stoodyind.../05catpg357.pdfhttp://www.stoodyind.../05catpg358.pdfhttp://www.stoodyind.../05catpg359.pdfhttp://www.stoodyind.../05catpg360.pdf.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I have been hard facing some field cultivator shovels I do the top point about 1/2 inch or so then turn them over and run a bead down the wings on the bottom side I don't have any pictures but can get some tomorrow. I finished a roll of Hobart and did not like it but the one I bought is lincoln and runs real nice for me hard facing is different than just welding at least for me. On the shovels if they don't look to good just put them and run them til there worn out then they don't look so bad. I will check the wire also and post with the photos
Reply:http://weldingweb.com/vbb/showthread.php...ets&highlight=Here is a thread I made years ago when I had done some hardface.Nothing Ever Got Done By Quitting, Never Give Up.
Reply:Some of those welds in that thread are pretty scabby by the way lol. Should have looked at it firstNothing Ever Got Done By Quitting, Never Give Up.
Reply:I will be building up and hard surfacing Grader scarifier shanks in the next couple of weeks. I normally use 7018 for the build up then 2 passes of wear shield 5/32 then wrap them in insulation or bury them in hot sand so they slow cool. The hard surface build up will check but the softer build up underneath won't So strength will not be compromised. Stoody used to have a book on hard surfacing and it covered everything from cultivator shanks to cone crushers. This book had good images and suggested consumables. I hope this helps you. I have a John Deere 450 dozer that I want to build a scarifier for to rip Glaciers when I open mining roads
Reply:Here are the photos of what I did for hard facing and wire that I used .045 flux cored wire shovel on left is lincoln and right is Hobart  I like the Lincoln better .
Reply:lol they look ugly....i surely can (giving my best shot) make it look worse...darn hard facingi prefer linclon too.
Reply:So conforting to read...
Reply:maybe i could have that statement laminated on a card to show the cops when they pull me over at 3am?i.u.o.e. # 15queens, ny and sunny fla
Reply:On those sweeps I would have hard faced the top instead of the bottom.  The top is what gets the most wear.  What little wear you get on the bottom will only sharpen the sweep as the softer metal erodes.
GMT+8, 2025-12-30 23:44 , Processed in 0.090388 second(s), 18 queries .
