Student shop project, trying to use up scrap metal
发表于 2021-8-31 22:34:52 | 显示全部楼层 |阅读模式
Here are a few desk organizers/paper weights the kids made in class using pipe, round stock and some "props" cut out with the CNC Plasma Cutter.  I think they did pretty good work.
Reply:Awesome!  Wish I could orient well enough to parallel beads like that.  I wander all over a flat plate and have trouble even seeing a fillet.  Must be doing several things wrong.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:That turned out great, I'll remember this when I get around to finishing my stump. Fyi, for the top of mine I took 1/4" round rod and welded it in as a big spiral. That gave me the ability to create an uneven surface for a bit more reality.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Here are a couple more shots Attached Images
Reply:They look awesome.  Great work!
Reply:Those are slick!
Reply:Can you tell me how you got the rust finish. I've tried the peroxide, vinegar and salt on some horse shoe's and couldn't get it to work.ThanksSammy
Reply:Awesome projects . Practice running beads and a project in one . Cool !
Reply:That is really kewel.  Someone has a passion for welding and they've figured out how to share that passion with the students, amazing.life is good
Reply:very nice work very nice!!  Clifton
Reply:We sandblasted them and then thinned down bleach with water and sprayed them.  It starts to rust pretty fast, after the kids leave I turned on all of the fans and added a little vinegar spray to the projects.  It speeds up the rust but produces chlorine gas that can be pretty nasty, so be careful!  After a couple of coats let it dry and hit it with some clear coat, the rust is pretty delicate.
Reply:that's really cool.  Gives me some ideas.  Good workLincoln MK 250, Syncrowayve 351, Cutmaster 151, SA 250D, bobcat 225  and want more.4 Daughters, 6 cats, 1 dog, 1 wife and don't want anymore.
Reply:Thanks will give that a try
GMT+8, 2025-12-30 23:44 , Processed in 0.092507 second(s), 18 queries .
