Mig welding a razor blade....
发表于 2021-8-31 22:34:51 | 显示全部楼层 |阅读模式
Got a customer of mine who calls me all the time and we BS on the phone about once a week. Guy has been welding for years and is all self taught. How he looks at things is so different than anyone else. He told me he can weld 2 razor blades together (box cutter blades) and we had a challenge. I tried it on tig and then he bought some and did it with his mig and he called me right after he did his best one ever. Then he sent it to me to see in person so I snapped some pics and sent it back to him. 2 box cutter blades BUTT welded. He put a clamp on both ends and as you can see in the pics one side is the butt and other side moved slightly to an overlapNO heatsink. No copper or aluminum backing.These are pictures of BOTH sides of the blade. 1 squeeze of the trigger ONLY, 1 pass on 1 side. It is not a high end machine and it's not pulsed. It's a standard transformer machine and that's all I will say. Because it really doesn't matter what welder he used. He used .023 wire of course. I tried it and no luck just yet.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:The quality of the blade makes a difference too, forget the HF bladesSent from my SCH-I545 using TapatalkTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Pretty cool!
Reply:Originally Posted by soutthpawThe quality of the blade makes a difference too, forget the HF bladesSent from my SCH-I545 using Tapatalk
Reply:They make extra thick razor blades also. Might wanna throw a caliper on those and see where they fall.....(Home)Miller Maxstar 152 (sold)MM211/spool gunLincoln AC 225C(Work)Dynasty 350Powcon 300STLincoln SP-175TWeldlodgic AWS150sWeldlodgic AWS300Custom Resistance seam weldersCambridge Vacuum EB weldersI smell something burning.
Reply:They are about .023Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I see he didn't get close to the ends. I used to weld .030" thick bandsaw blades together the same way. But the ends required pulsing to fill in.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:I did some steel banding a while back... just because. http://weldingweb.com/vbb/showthread.php...ing-band-steel
Reply:Originally Posted by irish fixitI see he didn't get close to the ends. I used to weld .030" thick bandsaw blades together the same way. But the ends required pulsing to fill in.
GMT+8, 2025-12-30 23:43 , Processed in 0.075204 second(s), 18 queries .
