SP135T and welding settings for 1/8"
发表于 2021-8-31 22:34:50 | 显示全部楼层 |阅读模式
Hi there, there's a blatant contradiction between online stores' marketing claims and the claims of lincoln themselves in regards to the thickness of material the SP135T welder can handle. Lincoln says it can weld up to 14ga (.075) steel on MIG mode and all of the online stores and ebay auctions say it can do up to 3/16" (.1875) steel with MIG. I purchased mine hoping it could do at least 1/8". So my questions is this : What  settings do users of the SP135T use out there to weld 1/8" steel? "Voltage Tap" options : A - DWire Speed options : 1-10On the lincoln chart it recommends D-7 for 14ga when using an argon mix gas, which I'm doing. Any levity in this situation would be very welcome. Ben_Friday________________________________________  [designer] www.fridayphotodesign.com   [mad_scientist] www.xylemsci.ca  [photographer] www.aspectphotos.net
Reply:I haven't seen a chart for the 135T yet, but I've seen the documentation on the Lincoln website.  The chart shows it does up to 3/16th on single pass.http://content.lincolnelectric.com/p...ature/e721.pdf
GMT+8, 2025-12-31 01:32 , Processed in 0.094318 second(s), 18 queries .
