Which product of Lincoln is for auto body repair?
发表于 2021-8-31 22:34:49 | 显示全部楼层 |阅读模式
Greetings from China.I am a newbie.Can you tell me which product of Lincoln is for auto body repair?The supplier voltage here is 220V and 380V.Not 110V over there.Does Lincoln produce automobile appearance repairer?Do you like Lincoln product?Thank youCaiwu
Reply:For a starter machine, look for a Lincoln Pro-Mig 175 or a 175SP.    The Pro-Mig 175 is a tapped machine with 5 voltage settings.  The 175SP has infinitely variable voltage control.   I have a Pro-Mig 175, and have used it for body repair   and it worked fine.There are no small projects
GMT+8, 2025-12-31 01:31 , Processed in 0.101853 second(s), 18 queries .
