Magnum 250 LX Spool Gun Voltage & Wire Feed Settings
发表于 2021-8-31 22:34:48 | 显示全部楼层 |阅读模式
I'm looking for anyone with working experience using the Magnum 250 LX Spool Gun.  I have mine set up for 4043 with the 3/64 tip.  The recommended settings in the Spool Gun manual are way too high.  I called Lincoln, but they have very little working data on this gun.  I tried to contact an engineer, but was only able to communicate with a marketing person.  I'm sure you know how taht turned out.  The best I can figure is that Lincoln printed power settings based on spray arc theory, instead of testing the gun itself.
GMT+8, 2025-12-30 23:42 , Processed in 0.118416 second(s), 18 queries .
