How would you repair this?
发表于 2021-8-31 22:34:44 | 显示全部楼层 |阅读模式
I broke a Lenox blade for my Ellis 1800 saw. How would you make this repair? Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Your saw will no longer work. Pack it up and send it to me and I'll be sure to deal with the problem promptly upon it's arival. .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWYour saw will no longer work. Pack it up and send it to me and I'll be sure to deal with the problem promptly upon it's arival.
Reply:Originally Posted by CEPI broke a Lenox blade for my Ellis 1800 saw. How would you make this repair?
Reply:I make my own bandsaw blades from coil stock.  I do up to 1".  I have silver soldered some, and I have tig welded some.  To silver solder, I use a very steep scarf joint, about 15 degrees from the length of the blade.  Lay one side of the blade against the other and grind both at once so the angles match.  For tig welding, I use inconel 625 filler.  Tig is faster for just one, silver solder is faster for several.  Either way, my success rate is about 80-90%.
Reply:Square up the ends and tig weld it. Smooth the weld and anneal with the smallest torch you have. Some people like to peen the weld but I don't.
Reply:Originally Posted by MinnesotaDaveWith a welder?
Reply:I tried soldering a blade back together for my 4x6 saw once. The blade made about 10 more cuts and broke in another location.My "collection":Homemade Stick WelderVictor O/A TorchAC 225Ideal Arc 250HF 90 Amp Flux CoreHF Mig 170Solar 2020 Plasma CutterPower i-Mig 140EHarris O/A torchHF Dual Mig 131140STAlpha Tig 200x
Reply:Originally Posted by CEPLike this?Oh God, I’m the world’s worst solderer! It all ends up on top of my feet!
Reply:CEP,I can see where you annealed it after welding (nice welding job BTW), but my question is what did you use to grind/file down the weld to get smooth operation?  The blade repair looks too rough for smooth operation.  Maybe its just the photo.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Originally Posted by storemanmy question is what did you use to grind/file down the weld to get smooth operation?
Reply:The same as I use on the blades I make from bulk stock.  Just saw no marks outside the blue area and wondered.  Guess I'm not too good with the angle grinder.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Nice fix. Did you AL back it and leave a gap?
Reply:submerge arc weld!VictorPraxairAir LiquideMillerLincoln Electric
Reply:My Do All has a built in blade grinder, and welder to allow you to do pierce work. It grinds the ends to mating angles, then uses resistance welds. I think I would braze them.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:we use to use a bandsaw welder in the machine shop , it was mounted to the side of the saw .http://www.zoro.com/dayton-welder-bl...Q&gclsrc=aw.ds
Reply:6013 downhill. GravelThe difference between theory and practice is that in theory there is no difference.
Reply:If CEP would just stop hoarding all those welding machines, he could easily afford an Ideal blade welder, grinder and shear. $300,000 isn't that much. http://www.ideal-werk.com/uploads/tx...S_englisch.pdf
Reply:Originally Posted by welderjJeezuz Carl, you need to cut some stuff with that saw, the table looks new yet. Lol. Mine has nearly nothing left between 90° and 45° on both sides.
Reply:Originally Posted by motolife313Nice fix. Did you AL back it and leave a gap?
Reply:Originally Posted by CEPYeah, it’s about time for a new one anyway!
Reply:Great save bro! That'll hold.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by CEPJon remember now, I’m just a hobbyist, and only been welding for a few weeks.
Reply:Originally Posted by weldermikeGreat save bro! That'll hold.The 2" blades throw some serious sparks when welded on a blade welder. The welders are water cooled.
Reply:Now you just need to learn to weld the teeth back in when one pops off.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldNow you just need to learn to weld the teeth back in when one pops off.
Reply:i saw on youtube a jig for silver-soldering band saw blades. our band saw at work has a blade welder/grinder but like everything else on my job looks like it was on noah's ark.i.u.o.e. # 15queens, ny and sunny fla
Reply:Didn't the old time weldors hammer-weld those things?Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Originally Posted by bentI make my own bandsaw blades from coil stock.  I do up to 1".  I have silver soldered some, and I have tig welded some.  To silver solder, I use a very steep scarf joint, about 15 degrees from the length of the blade.  Lay one side of the blade against the other and grind both at once so the angles match.  For tig welding, I use inconel 625 filler.  Tig is faster for just one, silver solder is faster for several.  Either way, my success rate is about 80-90%.
Reply:.piuhpiughpiLast edited by Kelvin; 06-15-2015 at 02:48 PM.
GMT+8, 2025-12-30 23:43 , Processed in 0.105673 second(s), 18 queries .
