Stupid question about auto-dark helmets
发表于 2021-8-31 22:34:42 | 显示全部楼层 |阅读模式
I have a speedglas and always forget to turn it on before I strike an arc. Is there some trick to remembering to turn this damn thing on on? I've done this twice now so obviously learning through pain isn't working.Lincoln PowerMIG 350mpEverlast PowerTIG 210EXT Hypertherm PowerMax45You merely adopted the iron, I was born in it, molded by it.
Reply:The trick is to sell the helmet to someone that really likes Speedglas, then get a Miller elite or my current favorite, the lincoln 3350. Auto on, never been flashed.SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Write on hood,  " TURN ON " !!!      OR get a fixed shade>
Reply:Get something similar to a turn the gas on dummy sticker.Sent from my SCH-I545 using TapatalkCRIME SCENES, COURT DATES, FUNERALS, RIDING THROUGH THE CITY WITH A BITCH THAT IS JUST BEAUTIFUL IT'S JUST BUSINESS AS USUAL.
Reply:[QUOTE=mikecwik;5980891]Get something similar to a turn the gas on dummy sticker.Good idea, Hang hood on tank so you turn on gas and hood .
Reply:[QUOTE=BD1;5981231] Originally Posted by mikecwikGet something similar to a turn the gas on dummy sticker.Good idea, Hang hood on tank so you turn on gas and hood .
Reply:On my Jackson Boss you will see black dots or circles to remind you to turn it on
Reply:flash yourself a few times, eventually you'll remember.
Reply:doojusGet used to it - it will happen occasionally the entire time you have the hood.Opus
Reply:Sell that one and get the Miller Digital Infinity™ Series Helmet   http://store.cyberweld.com/miwehebldiin.htmlThis has some nice features, Digital Infinity™ Features13.4 sq. in. viewing area provides the largest view in the industryInfoTrack® lens technology features arc time tracking, time and timer functions, and a multi-language help menu.Four arc sensors for superior lens responseFour Operating Modes - Weld, Cut, Grind, and X-ModeDigital controls allow user to easily adjust mode and settings      THIS   ******Auto-On/Off power control triggers lens at the strike of an arc **********Redesigned headgear with oversized comfort cushion provides extensive adjustability, settings, and enhanced support.Digital Elite™ SpecsComes complete with5 outside cover lenses2 inside cover lensesMag lens holderHelmet bagThree year lens warranty
Reply:At the end of the day or welding session you can adjust the headband to the smallest setting so every time you go to weld you have to adjust the helmet which should also remind you to check if the helmet is on. A thumbtack on the band could also work so it pokes you enough to remind you what its there for .You could also spend hundreds of dollars on a new helmet like others suggested.
Reply:don't be dumb!VictorPraxairAir LiquideMillerLincoln Electric
Reply:Originally Posted by BrazinThe trick is to sell the helmet to someone that really likes Speedglas....
Reply:My shield of choice today is a fibremetal small window flip front with an AD insert lens in it. No controls, no battery. Flip front for grinding and the AD insert make it a winner for me. Simple and effective.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by BD1Sell that one and get the Miller Digital Infinity™ Series Helmet   http://store.cyberweld.com/miwehebldiin.htmlThis has some nice features, Digital Infinity™ Features13.4 sq. in. viewing area provides the largest view in the industryInfoTrack® lens technology features arc time tracking, time and timer functions, and a multi-language help menu.Four arc sensors for superior lens responseFour Operating Modes - Weld, Cut, Grind, and X-ModeDigital controls allow user to easily adjust mode and settings      THIS   ******Auto-On/Off power control triggers lens at the strike of an arc **********Redesigned headgear with oversized comfort cushion provides extensive adjustability, settings, and enhanced support.Digital Elite™ SpecsComes complete with5 outside cover lenses2 inside cover lensesMag lens holderHelmet bagThree year lens warranty
Reply:Optrel e680. It's ready to work when I am. Pick it up and go.
Reply:Originally Posted by ManoKai(...) and the huge side windows.  WTF are side ports for?  Watching out for Great White Sharks during subsea welding?
GMT+8, 2025-12-30 23:43 , Processed in 0.095157 second(s), 18 queries .
