can someone educate me on these collets.
发表于 2021-8-31 22:34:41 | 显示全部楼层 |阅读模式
I have about 40 of these collets,  I was going to try to sell them but need to know more about the things, I have (i think) every size from small to large.... They worth anything? I assume there older........ Attached Images
Reply:Drill collets/taper sleeve. Probably Morse taper (MT), but can't really tell from the picture. Used to hold straight shank drill bits so they can be used in a drill press without reverting to a taper mounted drill chuck...save a little headroom. As to their worth, try eBay and look under completed auctions.Last edited by WyoRoy; 12-23-2010 at 03:57 PM.
Reply:Also used in tailstock of a lathe.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:They look like morse taper tap drivers, prolly Sculley/Jones.Look inside and see if there is a square pocket about 2/3rds down.There are drill drivers too from Scully but they are split once and have a drift slot to drive a straight shank drill with a tang from the morse adapter.Matt
Reply:AAAAHHHH. Mat your right, some are COLLIE and some are Scully.... and they do have a square down in there. Must be tap collets, I was thinking if they are for drill bits, than what is going to hold it from spinning in the collet?  I may keep a few of these, as my cheap tap holders are horrid to work with......The one in the picture states it is 1/2" P.T.   I wonder if that stands for  Pipe Tap...??
Reply:some are Brown & sharpe also....
Reply:Originally Posted by 1awert1AAAAHHHH. Mat your right, some are COLLIE and some are Scully.... and they do have a square down in there. Must be tap collets, I was thinking if they are for drill bits, than what is going to hold it from spinning in the collet?  I may keep a few of these, as my cheap tap holders are horrid to work with......The one in the picture states it is 1/2" P.T.   I wonder if that stands for  Pipe Tap...??
Reply:Thanks, i will check em out more closely later, i bought them all for a whopping $4 at a auction...
GMT+8, 2025-12-30 23:42 , Processed in 0.117089 second(s), 18 queries .
