Milwaukee 6180-20 vs DeWalt D287-15
发表于 2021-8-31 22:34:40 | 显示全部楼层 |阅读模式
I'm looking to buy a chop saw for my home shop. I've narrowed it down to the Milwaukee 6180-20 or the DeWalt D287-15. Both are right about $200 shipped to my door.Do any of you folks have any experience or preference with either.Thanks in advance,Wayne
Reply:Have personally used the Dewalt. Great saw. Glad to see Millwki. finally got their heads outta their arses and went with the d-handle. One thing that can be a make or break, IMHO, is the clamp quick release. Dewalt's is quick. Can't say regarding the Millwki.. Maybe check to see if both can be warranty serviced locally. Good luck.200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:i went with a craftsman it has a cast base did not want a stamped base Attached Images
Reply:I have rigids now but Milwaukee's are the next best (IMO).The D-handles are betterer too.The Dewalt's seem to take longer to spin up & I've had terrible personal luck with Dewalt tools over the years. (Except for my sawzall, it's been great).Buy American, or don't whine when you end up on the bread line.
Reply:my chop saw has been sitting sence i got my band saw Attached Images
Reply:Originally Posted by ed macmy chop saw has been sitting sence i got my band saw
Reply:I have used both. The milwaukee is much, much better.Ian TannerKawasaki KX450 and many other fine tools
Reply:Got a dewalt. POS. Can't cut straight to save my life.I bust out the torch before I use the dewalt
Reply:Originally Posted by phyisisist777Got a dewalt. POS. Can't cut straight to save my life.I bust out the torch before I use the dewalt
Reply:Milwaukee with the heavy cast base for sure.  Mine is very old and works great.  I had to replace a cracked handle and lost the rubber feat for it.  Went to Milwaukee's website, downloaded the parts diagram, found appropriate part numbers, then called Milwaukee and ordered the parts.  The price was low and shipping fast and the parts were exact replacements for the originals.  Milwaukee has excellent product support, even for tools that are several years old.My Milwaukee with the heavy cast base on the truck cuts much truer than the Makita with the stamped base in the shop.  The stamped base flexes too much.  I would never buy another chop saw with a stamped base.  They are lighter, but I would rather heft a heavier saw that works better.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by bert the welderInteresting. The one I used cut fine. As fine as any abrasive saw will cut. The blade can flex and wander to the side a bit if you're hanging off the handle.
Reply:Originally Posted by phyisisist777Relative to my brother's ridgid brand saw that is...
Reply:I bought the Milwaukee. Got it off Amazon for $192 with free shipping. Only bad part is I have to wait until Christmas to use it
Reply:I have the Milwaukee. It's a really nice chop saw. I've used it and some of the Dewalts (not sure of the exact numbers, but they had tool-less angle changing, etc) and both worked very well. I don't think you can go wrong with either one, but I like the cast base on the Milwaukee and the way the fence adjusts a bit better.KevinHobart Handler 210Tweco Fabricator 181iLincoln Squarewave Tig 175
Reply:Not sure what you're cutting, but I'd take a portaband over an abrasive saw any day of the week.Personally if you're going to consider the portaband I like the dewalts better.  I got the deep cut; the HD .025 blades, sight light and speed control were deal breakers that the milwaukee didn't have.
Reply:Milwaukee, just looking at them you got a go with Milwaukee.(I did)The base is cast and the hinge is way way stronger.Flounder
GMT+8, 2025-12-30 23:42 , Processed in 0.075461 second(s), 18 queries .
