Minimum number of machines to shear, roll and weld
发表于 2021-8-31 22:34:39 | 显示全部楼层 |阅读模式
I have to shear material to width, slip roll and weld all the way down the seam.  I have a few questions regarding the machinery required, and would really appreciate any help.Will this process require three separate machines, or has anyone seen anything that can do one or more of these steps on one machine?I do not want to be welding the seams by hand, I have to perform this process by the tens of thousands.  What machine would you guys recommend to put a good weld all the way down the seam?  The seam has to be airtight.Any help is much appreciated guys, I'm a newbie.
Reply:Contact a pivot manufacturer, they have machines that make pivot pipe out of rolls of flat steel.  Then take a tour & see what the machine does.  It ain't gonna be cheap to make this stuff.  The tour will be an eye opener.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:how does a newbie get himself in such a mess.......
Reply:If your user name means what I think it does, just sit the metal on the seat in the summertime, and it will get hot enough to fuse the joint, LOL.
Reply:I figured it wouldn't be cheap, what I'm trying to do now is put together an accurate cost.  Are you referring to the pivot pipe used for irrigation?
Reply:Yes.  Those machines are huge, but make seamless pipe up to 40' long, 6-8-10" in diameter at the push of a button.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
GMT+8, 2025-12-30 23:44 , Processed in 0.098416 second(s), 18 queries .
