38 ton mubea model kbl-o universal ironworker
发表于 2021-8-31 22:34:35 | 显示全部楼层 |阅读模式
38 TON MUBEA MODEL KBL-O UNIVERSAL IRONWORKERBAR SHEARS:ANGLES AND TEES ------------------------- 2.5" X 3/8"CHANNELS 90 DEGREES --------------------- 3" X 1.5"BEAMS 90 DEGREES ------------------------ 2.5" X 1.25"ROUND BARS ------------------------------ 1-5/16"SQUARE BARS ----------------------------- 1-3/16"PLATE SHEARS:SLITTING -------------------------------- 7/16"FLAT BARS ------------------------------- 5" X .5"ANGLE SHEAR:ANGLES 90 DEGREES ----------------------- 3-1/2" X 3-1/2" X 3/8"TEES 90 DEGREES ------------------------- 3" X .375"CHANNELS 90 DEGREES --------------------- 5" X 1.875"BEAMS 90 DEGREES ------------------------ 4" X 2.625"PUNCH:PRESSURE -------------------------------- 38 TONSHOLE DIA. IN THICKNESS OF MATERIAL ------ 1" THROUGH 7/16"ELECTRICS --------------------------------- 2 HP A.C.EQUIPPED WITH ---3 SEPARATE CLUTCHESCOPER/NOTCHERFOOT CONTROLWEIGHT: 2800 LBS.DIMENSIONS (IN.): 60 X 39 X 80Located in Oakland, CA   Very low use machine stored inside unused for the last 10 years everything works and runs great, currently under power.    $3,200  I can arrange delivery within 250 miles of Oakland.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Some pictures.  It has some black over spray from some careless paint spraying,  other than that its a super clean low use unit.Last edited by Dualie; 04-13-2010 at 09:22 PM.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-31 03:23 , Processed in 0.113213 second(s), 18 queries .
