oxyacetylene welding
发表于 2021-8-31 22:34:31 | 显示全部楼层 |阅读模式
I was using my welder (OXY) and the handles of my torch got hot  anybody know why and what's going on? Thank You!
Reply:I have somewhat of an idea.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:So what is it? And what should I do?
Reply:Sound like burn back into your handle....very badSent from my SPH-D700 using Tapatalk 2Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:What brand of torch ? What were you doing ? Cutting or welding ? If it's a Victor WELDING tip make sure the tip is tight in the brass nipple. Pretty common with the crappy threading on the cheaper aftermarket tips.If you're cutting with LP you have your flame all wrong.. See why I shorted you.BTW my brakes are squeaking. Any idea what it is ?Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by BurpeeBTW my brakes are squeaking. Any idea what it is ?
Reply:Originally Posted by MinnesotaDaveWhat color is the car? Blue ones tend to squeak more often...
Reply:Originally Posted by BurpeeIt is blue ! But the sound is coming from the ascz end
Reply:Only two ? There's room for about 11.3 in this oneBubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:I was referring to the head - that's where the majority of the noisy nonsense seems to spill out
GMT+8, 2025-12-31 01:10 , Processed in 0.111831 second(s), 18 queries .
