How to make Aluminum wall art? Please give tips on grinder attachements techniques
发表于 2021-8-31 22:34:29 | 显示全部楼层 |阅读模式
above is one example if you google aluminum wall art photos you will see a hundred more examples. and Yes I did google how to do it, but after searching for an hour got very few specific tips. just this one forum that touched on it brieflyhttp://www.metalartistforum.com/maf/...ring-aluminum/here are my questions. 1. what paint is used that will stick to aluminum?2. what techniques are used to make the lines on the aluminum?3. assuming it is done via angle grinder, what attachements would be most used? brass wire cup? wheel flap? wire wheel? standard gridning wheel?4. anyone try this and have some example how to's?Not looking to make money off this, just something fun to do with some scraps I have lyiung around. thanks !Last edited by AluminumWelder; 03-26-2014 at 11:47 PM.
Reply:Roloc disks or flap wheel will do that.My name's not Jim....
Reply:I met a guy that did this for a living. Had the coolest house I've ever seen, very creative. Had work like this all over the house. Some curved, some that look like a surf board with lights behind it. He had an aluminum backsplash in his kitchen that was purple with lights under it. I wish I had an creative mind for this stuff.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleI met a guy that did this for a living. Had the coolest house I've ever seen, very creative. Had work like this all over the house. Some curved, some that look like a surf board with lights behind it. He had an aluminum backsplash in his kitchen that was purple with lights under it. I wish I had an creative mind for this stuff.
Reply:PPG DAU75 for bare metal. Add solvent tints from PPG or house of color. Works well, is expensive as hell. I have been using ClearGuard from Sculpt nouveau with their own solvent dies for several years. They work well, are easy to use  and are much more affordable.
GMT+8, 2025-12-31 01:02 , Processed in 0.111587 second(s), 18 queries .
